New Reply
API Q125 - what does it mean?
Share Thread Thread Tools
Nov1-12, 04:18 AM   #1
Hi,
can someone please clarify me what does the standard "API Q125" in material designation mean?
Does it stand for one particular steel grade or it has something to the with physical properties?
And what does this "Q125" exactly means?
Thank you.
Regards
Amy
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Nov27-12, 10:19 PM   #2
Other Sciences 2012
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Q125 is the API standard number.
Dec3-12, 09:05 AM   #3
thank you, chemisttree, for your answer.
do you prehaps know where can I find itīs chemical and physical properties? Iīve tried searching all over the internet, but I couldnīt find anything.
I would appreciate it very much..
Dec3-12, 11:50 AM   #4
Recognitions:
Looks like the API standard is 5AQ. The Q125 is probably something listed in the spec. But 5AQ is no longer being used. IHS states:
SPECIFICATION FOR Q125 CASING (COMBINED WITH SPEC 5A, 5AC, AND 5AX INTO SPEC 5CT-88)
Note that the -88 on API 5CT-88 is just the year of publication so look for API 5CT instead. API 5CT comes up as active. You can Google that here:
http://www.google.com/#hl=en&safe=ac...w=1280&bih=901
EDIT: Just to clarify, if you have some old Q125 casing built to API 5AQ and you need the chemical and physical properties, you have to purchase the defunct spec from IHS or whoever you get your industry standards through. If you're looking for those properties because you need the casing for a new project, use API 5CT. Hope that isn't too confusing!
Dec3-12, 02:22 PM   #5
Recognitions:
In the catalog at the following link:
http://www.voestalpine.com/tubulars/...05-2010_SC.pdf
there are appendices which contain various physical and chemical properties for the various grades of API 5CT tubulars (including Grade Q125).
There is also a draft standard for API 5CT at the following link:
http://ballots.api.org/ecs/sc5/ballots/docs/5CT_na.pdf
The information in this draft standard is of course unofficial.
New Reply
Thread Tools
