Solving a MATLAB Problem with 3 Variable Integration
The discussion revolves around a MATLAB problem involving three-variable integration of a function dependent on variables x, y, z, m, and a. Participants are exploring how to perform the integration over x, y, and z while solving for m given a specific value of a.
  • One participant describes a need to perform a three-variable integration in MATLAB and solve for m given a constant a, but encounters an error related to the symbolic variable m.
  • Another participant suggests that the triplequad function is a numerical integration routine and may not support symbolic variables, indicating that the integration should be approached numerically rather than symbolically.
  • A suggestion is made to pass m as an additional parameter to the function f, which could allow for the integration to be computed correctly.
  • Some participants emphasize the importance of using nested functions in MATLAB to access outer function variables, proposing a structure for the integration that includes m as a parameter.
  • One participant expresses confusion about the initial guidance, clarifying that they do not have an initial guess for m and want to find the value of m that makes the integration result equal to a specific number.
  • Another participant confirms that the proposed method of using fsolve to find m is indeed aimed at making the integration result zero when set against the constant value.
  • A later post introduces a new function and reports errors encountered when attempting to apply the previously discussed method, prompting further inquiry into the cause of these errors.
There is no consensus on the best approach to resolve the integration and solving for m, as participants present differing views on the use of symbolic versus numerical methods and the structure of the MATLAB code.
Participants express uncertainty regarding the handling of symbolic variables in numerical integration routines and the implications of using nested versus anonymous functions in MATLAB. There are also unresolved issues related to specific errors encountered in the implementation of the proposed solutions.
quin
dear friends
i want to do set of operation in MATLAB but i have a problem:
first of all, i want to take 3variable integration from f which is function of x,y,z,m,a
but i want to integrate only over x,y,z
after that for a special "a" forexample a=0.01 i want to solve the equation.i mean one side of equation is the answer of that 3variable integration and the other side is just a number
in MATLAB my program is:
a=0.01
syms m a x y z
f = inline(vectorize((2/m)-(2*a*(4+a*m))/(-(4+a*m)^2+(cos(0.25*(x-y)))^2+(cos(0.25*(x+y)))^2+(cos(0.5*x)+cos(0.5*y))*cos(0.5*z))),'x','y','z')
S = solve(330.734- triplequad(f,0,2*pi,0,2*pi,0,2*pi), m)
so for a special "a" i must find special "m"
but when i write it in matlab, it give error for "m"
but because i know the answer of "m" from somewhere else , when i put m and a in integration and solve equation it becomes true.
so what should i do?
I don't have the MATLAB symbolic toolbox so I'm not well versed with this. However I'm pretty sure that triplequad is a purely numerical integration routine, so I'm guessing that it is unable to handle the symbolic variable "m".
BTW. I'm not even sure that anything you're doing here is symbolic. "a" is given a constant value and x,y,z will be given numerical values (the function evaluated at numerical values) in the triplequad routine. I'm certain that if "solve" can do anything for you here it will be numeric and not symbolic.
uart said:
It looks like this might work if you were able to pass "m" as an additional parameter to "f". See "parametrizing functions" here: http://www.mathworks.com.au/help/matlab/math/parameterizing-functions.html
Thanks dear I saw that site but I couldn’t get my purpose
Let me ask my question in a different way. Tell me a way for taking multivariable integration from a function which is in terms of x,y,z,m , ((3variable integration over ' x,y,z')), and give the answer in terms of "m"
Thank you
Thank you
The basic idea is that if you write nested functions in matlab, then the inner function gets access to the outer function's variables. I think the website explains it well enough.
Firstly you need to understand that you are working numerically, NOT symbolically. You don't want the "syms" statement. What you do need to do is to write a function to takes the single variable "m" and returns the numerical integral for this given parameter. Use triplequad in a nested function like as follows (type this as a ".m" file ok).
Code:
function myint = getintegral(m)
a = 0.01;
myint = 330.734 - triplequad(@myfunction,0,2*pi,0,2*pi,0,2*pi);
  function myfun = myfunction(x,y,z)
  (2/m)-(2*a*(4+a*m))/(-(4+a*m)^2+(cos(0.25*(x-y)))^2+(cos(0.25*(x+y)))^2+(cos(0.5*x)+cos(0.5*y)) *cos(0.5*z)));
  end %myfunction
end %getintegral
See how the nested function (myfunction) works. It allows us to use parameters "a" and "m" in addition to the parameters x,y and z that are actually passed to the function.
Then from the command line you can just type something like:
> fsolve(@getintegral,m_initialguess)
BTW. I didn't check your syntax, just copied and pasted it ok.
An addendum for anyone using gnu-Octave as a freeware MATLAB clone. Unfortunately Octave doesn't extend the scope of a functions variables into its nested functions, so the above doesn't work.
An alternative method using "anonymous" functions can achieve the same result. This should work equally well on MATLAB too. Here's an example using a simple one dimensional integral (quad).
1. Write a function for the integrand.
Code:
function myfun = mytestintegrand(x,s)
% called from getintegral.m
  myfun = exp(-(x/s)^2/2)/sqrt(2*pi)/s;
end
2. Write a function to evaluate the integral in terms of the auxiliary parameter ("s") by using the anonymous "@ function" to cast the original function into a function of just "x" (for each given value of parameter "s").
Code:
function myint = getintegral(s)
  myint = 0.25 - quad( @(x) mytestintegrand(x,s), 0,1);
end
3. Call fsolve (for example) from the command line.
> fsolve(@getintegral, 1.0)
Code:
a = 0.01;
  end %myfunction
end %getintegral
Many thanks for your reply but sorry i think that you made a mistake with what i wanted to say. I don't know the value of "m" atall and also i don't have any m_initialguess . Instead, i want "my int" to be zero
I mean that the term which is in parentheses of solve in my first quote must be zero and with knowing that,i must find "m":
S = solve((330.734- ...)==0, m)
in other words, the functiom which you introduce as "my int" is 0.
I want to solve the equation in which one side of equation is the answer of that 3variable integration and the other side is just a number "330.734"
I would appreciate if you could help me with your excellent guidance
Yes that is what the above does. It solves to find the value of "m" for which,
is zero.
uart said:
Code:
a = 0.01;
  myfun=(2./m)-(2*a*(4+a*m))./(-(4+a*m).^2+(cos(0.25*(x-y))).^2+(cos(0.25*(x+y))).^2+(cos(0.5*x)+cos(0.5*y))*cos(0.5*z));
  end %myfunction
end %getintegral
Hi friend
some days ago I asked 1qestion from you(above explanation)
I test my function( in above code) and found answer for m and it worked
but now I want to use this way for another function but it gives eror.
can you tell me that why those erors are given?
Let me put my code in another post below:
Code:
function myint=getintegral(m)
a=100;
myint=330.734-triplequad(@myfunction,-pi,pi,-pi,pi,-pi,pi);
    function myfun=myfunction(x,y,z)
        myfun=triplequad((4 *((-2* a + m).^2 *(4 *a + m) +4 *a.^2 *(2*(2*a - m)* cos(z) + cos(y) *(4* a - 2* m + 4 *a* cos(z) - m *cos(z)) + cos(x) *(4* a - 2* m + 4 *a* cos(z) - m *cos(z) +  cos(y) *(4 *a - m + 4 *a* cos(z))))))./(m.^4 + 64 *a.^3 *m *(1 + cos(x)) *(1 + cos(y)) *(1 + cos(z)) - 8 *a.^2 *m.^2 *(3 + 2 *cos(z) + cos(y) *(2 + cos(z)) + cos(x) *(2 + cos(y) + cos(z))) + 16 *a.^4 *(-3 + cos(x).^2 *(cos(y) - cos(z)).^2 - 4 *cos(z) + cos(y) *(-4 + cos(z) *(-6 + cos(y) *cos(z))) - 2 *cos(x) *(2 + 3 *cos(z) +  cos(y) *(3 + cos(z)* (6 + cos(y) + cos(z)))))),-pi,pi,-pi,pi,-pi,pi);
    end %myfunction
end %getintegral
and after that use fsolve
also i must tell that I used ./ instead of / and also .^ instead of ^ because if I didnt do that Matlab couldn't solve and said that x y z are matrix
in the last code in above post, I did the same and I reach to answer.
I would appreciate if you could help me with solving this new function too
because I can not understand Matlab's erors
quin said:
Code:
a=100;
    end %myfunction
end %getintegral
I forgot to tell you; my answer( I mean values for "m") is around 3.so take m_initial = 3
