Current through inductor in a circuit with a sinusoidal voltage source
The discussion focuses on calculating the current through an inductor in a circuit with a sinusoidal voltage source, specifically using an 8 H inductor. The key equation used is vL = L * (diL / dt), leading to the derived current iL = (6 / 8) * ∫ cos(100t) dt = 0.0075 sin(100t). The participants clarify that the initial current iL(t0) can be assumed to be 0 at t0 = 0, as the inductor does not allow instantaneous changes in current when a voltage is suddenly applied.
  • Understanding of inductors and their behavior in circuits
  • Familiarity with calculus, specifically integration
  • Knowledge of sinusoidal voltage sources
  • Basic principles of electrical engineering
  • Study the behavior of inductors in AC circuits
  • Learn about the Laplace transform for circuit analysis
  • Explore the concept of initial conditions in differential equations
  • Investigate the relationship between voltage and current in inductive circuits
Electrical engineering students, circuit designers, and anyone studying the dynamics of inductors in AC circuits will benefit from this discussion.
AbbeAbyss
http://www.wifstrand.se/Albert/stuff/p7.7-1.png
vL = L * (diL / dt).
All of the inductors can be reduced to a single 8 H inductor, so
iL = (6 / 8) * ∫ cos 100t dt = 0.0075 sin 100t
if you integrate from 0 to t.
The formula states that iL = iL(t0) + ∫ vL dt if you integrate from some initial condition current t0 to t. I get the correct answer if I integrate from 0 to t, but I fail to see what iL(t0) is and how we can use 0 for the lower bound.
It seems as if we can just assume that t0 = 0 and that iL(t0) = 0, if so, why is that?
You have di/dt = V/L so
i = ∫(V/L)dt + constant (indefinite integral + a constant)
To evaluate the constant, asume V = 0 for t < 0. Then, at t = 0, a sudden voltage V = 6V is applied to L. What is the current then at t = 0? What is the constant? Do you see now why your last statement is correct?
Yes, I see now that at t = 0 (or rather t = 0+ denoting the exact moment the voltage 6 * cos 0 is applied) the current is 0 since the current through an inductor can't change instantaneously, thanks.
12K
