Normal to a fixed concentric ellipse
  • Thread starter Thread starter utkarshakash
    Ellipse Normal
The discussion revolves around proving that the line segment MN is always normal to a fixed concentric ellipse, given perpendiculars PM and PN from a point P on the ellipse. The problem involves understanding the geometric properties of ellipses and their normals.
  • Participants explore the equation of the normal to an ellipse and attempt to relate it to the equation derived from point P on the ellipse. There are discussions about expressing parameters in terms of others and ensuring the equations align under certain constraints.
Participants are actively comparing equations and deriving relationships between parameters. There is a focus on ensuring that the derived equations can accommodate all values of the angles involved, indicating a productive exploration of the problem.
There are constraints regarding the dependencies of parameters a', b', and φ on a, b, and θ, which are being discussed to ensure the validity of the relationships being formed.
utkarshakash
PM and PN are perpendiculars upon the axes from any point 'P' on the ellipse. Prove that MN is always normal to a fixed concentric ellipse
I assume point P to be (acosθ, bsinθ)
The eqn of line MN is then given by
[itex]bsin\theta x+acos\theta y =absin\theta cos\theta[/itex]
Try writing the generic equation for a normal to an ellipse with same centre and axes.
[itex]a'sec \phi x - b'cosec \phi y = a^2 - b^2[/itex]
I assume you meant [itex]a'sec \phi x - b'cosec \phi y = a'^2 - b'^2[/itex]
It remains to find expressions for a', b' and phi in terms of a, b and θ that make this the same as the equation for MN. There is a constraint regarding which of a', b' and phi can depend on which of a, b and θ.
Do you want me to compare the two lines?
Yes. You want to make a′x sec(ϕ)−b′y cosec(ϕ)=a′2−b′2 look like bx sin(θ)+ay cos(θ)=ab sinθ cosθ by suitable choices of a', b' and ϕ. But note that this must work keeping a' and b' fixed while ϕ is allowed to vary as a function of θ.
OK I did exactly what you said and got the following relations after comparison
[itex]cos\alpha = \dfrac{aa'cos\theta}{a'^2 - b'^2} \\<br /> <br /> sin \alpha = \dfrac{-bb'sin\theta}{a'^2 - b'^2} \\ <br /> <br /> tan \alpha = \dfrac{-bb' tan\theta}{aa'}<br /> [/itex]
OK, nearly there. Now you must set a' and b' so that all values of θ and α can occur. (Otherwise there will be a gap in one of the ellipses.)
  • · Replies 18 ·
