Solving Diffraction Problem: Calculating Slit Width with He-Ne Laser
  • Thread starter Thread starter Naeem
    Diffraction
The discussion focuses on calculating the width of a single slit (D) using a He-Ne laser with a wavelength of 633 nm. The setup involves measuring the distance between the first minima on either side of the central maximum, which is 2.3 cm, at a distance of 2.0 m from the slit. The correct formula applied is D = λY/M, leading to a calculated slit width of 110 μm. This calculation confirms the relationship between wavelength, distance to the screen, and slit width in diffraction problems.
  • Understanding of diffraction patterns and minima
  • Familiarity with the He-Ne laser specifications
  • Knowledge of basic trigonometry and small angle approximations
  • Ability to manipulate scientific notation in calculations
  • Study the principles of single-slit diffraction in detail
  • Learn about the He-Ne laser's properties and applications
  • Explore advanced diffraction calculations involving multiple slits
  • Investigate the impact of slit width on diffraction patterns
Physics students, optical engineers, and anyone interested in wave optics and diffraction phenomena will benefit from this discussion.
Naeem
Q. A He-Ne laser of wavelength (633nm) shines thru a single slit of unknown width D on to screen 2.0m away from the slit. The distance on the screen between the m = 1 minima on either side of the central maximum of the diffraction pattern is measured and is found to be 2.3 cm. What is the width of the slit?
Ans. I did,
ym = wavelength * D/d
Is this right.
Please help, me folks...
{Distance From Central Maximum To First Minimum On Screen} = M =approx= λY/D
where "λ" is the wavelength, "Y" the distance to screen, and "D" the single slit width. For this problem, we are given {λ = 633e(-9) m}, {Y = 2 m}, {M = (2.3 cm)/2 = 0.0115 m}, so that:
D = λY/M = {633e(-9)}*(2)/(0.0115) = {1.1e(-4) m} = (110 μm)
if you are confused about that i think that he used:
dsin(theta)=m*lambda
and for small theta
sin(theta)=tan(theta)
and in this case, tan(theta)=Size projected on screen/distance to screen
  • · Replies 34 ·
