Calculate Perihelion Distance of Mars Using Solar System Parameters
The perihelion distance of Mars, calculated using the semi-major axis of 1.5237 AU and eccentricity of 0.0934, is definitively 1.38 AU. The formula used for this calculation is r = a(1 - e^2) / (1 + e cos θ), where θ is 0°. Initial miscalculations led to an incorrect result of 16.17 AU, but upon reevaluation, the correct perihelion distance was confirmed.
  • Understanding of orbital mechanics and Kepler's laws
  • Familiarity with the formula for calculating perihelion distance
  • Basic knowledge of astronomical units (AU)
  • Proficiency in using scientific calculators for trigonometric functions
  • Study the derivation of the perihelion distance formula in celestial mechanics
  • Explore the implications of eccentricity on planetary orbits
  • Learn about the orbital parameters of other planets in the solar system
  • Investigate the effects of gravitational perturbations on perihelion distances
Astronomy students, astrophysicists, and anyone interested in celestial mechanics and planetary motion will benefit from this discussion.
ZedCar
Assuming that the sun lies at the principal focus of the solar system, and given that the semi-major axis and eccentricity of Mars is 1.5237 AU and 0.0934 respectively, calculate:
The distance (in AU) when Mars is closest to the Sun (known as perihelion). The angle θ=0°
r = a(1 - e^2) / (1 +e cos θ)
The correct solution is 1.38 AU
Though if I use the above eqn putting a=1.5237 and e=0.0934 I get an answer of 16.17.
Thanks for any help!
Must be finger problems with the calculator :smile:
What values do you calculate for the numerator and denominator of the expression?
Sorry about that! I'm getting the correct answer now...!
  • · Replies 21 ·
