Single slit diffraction
by GeneralOJB
Tags: diffraction, single, slit
GeneralOJB
GeneralOJB is offline
#1
Jan3-13, 01:42 AM
P: 26
I'm confused about the single slit diffraction pattern. Why are light and dark patterns? Where is the constructive and destructive interference occuring if there is just one wave?
Phys.Org News Partner Physics news on Phys.org
Physicists design quantum switches which can be activated by single photons
'Dressed' laser aimed at clouds may be key to inducing rain, lightning
Higher-order nonlinear optical processes observed using the SACLA X-ray free-electron laser
Drakkith
Drakkith is online now
#2
Jan3-13, 01:56 AM
PF Gold
Drakkith's Avatar
P: 11,040
The wave interferes with itself. You can consider the wave to be composed of many smaller "wavelets" and these all add up to give the interference pattern. See the following article.
http://en.wikipedia.org/wiki/Diffraction_formalism
GeneralOJB
#3
Jan3-13, 01:59 AM
P: 26
So when doing the double slit experiment, one will see two diffraction patterns on top of each other then?
vanhees71
vanhees71 is online now
#4
Jan3-13, 03:08 AM
Sci Advisor
Thanks
P: 2,137
The most simple picture about diffraction comes from using the Fraunhofer case (both source and detection screen at infinity) and Kirchhoff's approximate formula. Then the diffraction pattern seen at the screen turns out to be given by the Fourier transform of the openings, i.e., the electric field is proportional to this Fourier transform.
The physical picture behind this is that any point of the opening is the source of a wave, and at the infinitely far away screen you can approximate the spherical wave by a plane wave (Fraunhofer diffraction).
You find the math in great detail at the Wikipedia link in GeneralOJB's posting.
Drakkith
#5
Jan3-13, 03:20 AM
PF Gold
Drakkith's Avatar
P: 11,040
Quote Quote by vanhees71 View Post
I think he means my post.
Register to reply
Related Discussions
Diffraction through a single slit Introductory Physics Homework 2
Single-Slit Diffraction Introductory Physics Homework 1
Single-Slit Diffraction Classical Physics 10
Help!! Single slit diffraction Introductory Physics Homework 20
