How to Determine Gas Pressure Using Two Different Pressure Gauges?
The discussion focuses on calculating gas pressure using two different pressure gauges: one with liquid mercury and the other with dibutyl phthalate oil. The observed height difference in the mercury gauge is 9.50 cm. Using the formula P = ρgh, the pressure of the gas can be determined by substituting the density of mercury (13.60 g/cm³), the height difference, and the gravitational constant (9.806 m/s²). Subsequently, the height difference in the oil gauge can be calculated using the gas pressure obtained and the density of the oil (1.045 g/cm³).
  • Understanding of hydrostatic pressure principles
  • Familiarity with the formula P = ρgh
  • Knowledge of density measurements in g/cm³
  • Basic grasp of gravitational acceleration (9.806 m/s²)
  • Calculate gas pressure using P = ρgh with mercury density and height difference
  • Determine the height difference in dibutyl phthalate using the gas pressure
  • Explore variations in pressure gauge types and their applications
  • Research the properties and uses of dibutyl phthalate in pressure measurement
Students and professionals in physics, engineering, and fluid mechanics who are interested in pressure measurement techniques and calculations.
mahrap
1. A vessel that contains a gas has two pressure gauges attached to it. One contains liquid mercury, and the other an oi lsuch as dibutyl phthalate. The difference in levels of mercury in the two arms of the mercury gauge is observed to be 9.50 cm.Given
density of mercury =13.60 g cm-3
density of oil = 1.045 g cm -3
acceleration due to gravity = 9.806 m s-2
(a) What is the pressure of the gas?
(b) What is the difference in height of the oil in the two arms of the oil pressure gauge?
2. Pressure = density * g * h
3. for part a, do i find the pressure of the gas by using P=pgh and just plugging in the density of mercury, the height difference, and the gravitational constant?
and can i just use that answer to find the difference in height of the oil by using P=pgh with P=the pressure from a, g, and p=the density of oil?
If I understand the problem correctly - yes.
21K
