Cracking the Code: Solving Cylindrical Shells with Gauss's Law
The problem involves a cylindrical shell with a specified length and radius, carrying a uniform surface charge density. The task is to determine the total charge on the shell and the electric field at a specified radial distance from the long axis of the cylinder. The context includes the application of Gauss's Law, which has not yet been covered in class.
  • Participants discuss the implications of the observation point's location relative to the cylindrical shell and question how this affects the application of Gauss's Law. There is uncertainty regarding the phrasing of the problem, particularly the meaning of "at the end" in relation to the cylinder and the radial distance.
The discussion is ongoing, with participants raising important questions about the clarity of the problem statement and its implications for applying Gauss's Law. Some guidance has been offered regarding the interpretation of the observation point's location, but no consensus has been reached on the correct approach.
There is a lack of clarity in the problem statement regarding the observation point's position along the length of the cylindrical shell, which may affect the application of Gauss's Law. Additionally, the participants note that the topic has not yet been covered in their coursework, adding to the complexity of the discussion.
Klymene15
"A cylindrical shell of length 230 m and radius 6 cm carries a uniform surface charge density of σ = 14 nC/m^2. What is the total charge on the shell? Find the electric field at the end of a radial distance of 3 cm from the long axis of the cylinder."
Gauss's Law
Volume of a cylinder=∏r^2*h
The textbook hints that it has something to do with Gauss's law. As I searched for hints online, I only found answers with cylindrical shells with infinite lengths. The fact that we still haven't covered Gauss's Law in class (this is due tomorrow at noon), probably doesn't help either.
So maybe... a quick, crash course on how I'm suppose to use Gauss's Law for a problem like this, and how to do it? The set up, at least?
The question doesn't tell you how far along the length of the shell the observation point is, and seems to me that matters. But if its 3 cm from the middle of the shell (i.e. 115m from either end) then Gauss's law can be applied to compute the E field as described.
It says "Find the electric field at the end of a radial distance of 3 cm from the long axis". Not very clear, but it sounds to me that it is at the end of the cylinder, 3cm from the axis. (Otherwise, why bother to specify the length?)
Confusing statement still. "At the end" could mean at the end of the radial distance or the end of the cylinder. "At the end OF ... " doesn't sound like they meant the end of the cylinder to me.
The length still matters unless you're at the center of the cylinder, axially speaking.
BTW I think this is intended to be a trick question.
  • · Replies 26 ·
