Harmonic Motion Problems: Solving for Maximum Speed and Velocity after Collision
  • Thread starter Thread starter ness9660
    Stuck
This discussion focuses on solving harmonic motion problems involving collisions and maximum speeds. A 66.3 g mass attached to a vertical spring with a constant of 63.5 N/m is analyzed for its maximum speed when dropped, utilizing Newton's second law. Additionally, a collision problem involving a 1.6 kg object striking a stationary 1.2 kg object is examined, where the post-collision velocities are calculated using conservation of momentum in both x and y directions. The correct approach requires understanding the angles involved in the collision and the application of harmonic motion principles.
  • Understanding of harmonic motion principles
  • Knowledge of Newton's second law
  • Familiarity with conservation of momentum
  • Ability to solve vector problems involving angles
  • Study the derivation of maximum velocity in harmonic motion systems
  • Learn about vector decomposition in collision problems
  • Explore the application of conservation laws in two-dimensional collisions
  • Review examples of spring-mass systems and their dynamics
Students and educators in physics, particularly those focusing on mechanics, collision analysis, and harmonic motion applications.
ness9660
1. A 66.3 g mass is attached to the end of
an unstressed vertical spring (of constant
63.5 Nm) and then dropped.
The acceleration of gravity is 9.8 m/s2 :
What is its maximum speed? Answer in
units of m/s.
Im not quite sure that I understand what this problem is saying. Is the block hanging from the spring? Is it on top of the spring? I am not sure how this system is setup, but beyond that it is a harmonic motion problem, correct?
2.A(n) 1.6 kg object moving at a speed of
6.5 m/s strikes a(n) 1.2 kg object initially
at rest. Immediately after the collision, the
1.6 kg object has a velocity of 0.88 m/s di-
rected 46 degrees from its initial line of motion.
What is the speed of the 1.2 kg object
immediately after the collision? Answer in
units of m/s.
Ive been doing it like this:
X direction: m1i*v1i=m1i*v1f*cos(46) + m2*v2f*cos(46)
Y direction: m1*v1i=m1*v1f*sin(46) + m2*v2f*sin(46)
and then v2f= sqrt(x^2 + y^2)
However this is apparently wrong, am I close in my approach to this problem?
I believe the other end of the spring is attached to a ceiling. If that is the case, then you can apply Newton's second law to a point where the mass has moved a distance x from it's equilibrium position.
mg - kx = m d^2 x/ dt^2 and solve for dx/dt. That will lead you to the maximum velocity.
You have assumed that mass m2 travels in the same direction as m1 after the collision. This assumption is wrong. Assume that m2 travell in a direction theta with respect to the original direction of m1.
m1i*v1i=m1i*v1f*cos(46) + m2*v2f*cos(theta)
0 =m1*v1f*sin(46) - m2*v2f*sin(theta)
solve for theta.
  • · Replies 17 ·
  • · Replies 17 ·
