Electron in magnetic field and center of circumference
The discussion revolves around determining the center of the circular path of an electron moving in a uniform magnetic field, specifically when the electron's initial position and velocity components are given. The problem is situated within the context of electromagnetism and motion in magnetic fields.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the use of the Lorentz force equation and attempt to derive the radius of the electron's path. There are questions about the relationship between the direction of motion and the location of the center of the circular path. Some participants explore the geometric implications of the motion and the need for orthogonal vectors in their reasoning.
The discussion is ongoing, with participants exploring various interpretations of the problem. Some guidance has been provided regarding the use of orthogonal vectors and geometric relationships, but there is no clear consensus on the next steps or a definitive approach to finding the center of the circumference.
Participants are working under the constraints of using only the given coordinates and velocities at a general time t, and there is an emphasis on understanding the geometric relationships involved in the motion of the electron.
bznm
We have an electron in 3D space in which there is also a magnetic uniform field B=Bz.
At t=0, we have z=0 and $v_z=0$.
We have to find the center of the circumference traveled by the electron using only x, y, v_x and v_y (coordinates and velocity of the electron at the general istant t) .
$$L_F= qv×B$$ : this is the equation of Lorentz force.
The first thing that I have done was finding the radius: $R=\frac{mv}{qB}$
Then, I have thought that I could obtain the center considering:
$$R_x= \frac{m \dot x}{qB} \rightarrow x-x_c=\frac{m \dot x}{qB} $$
$$R_y= \frac{m \dot y}{qB} \rightarrow y-y_c=\frac{m \dot y}{qB} $$
.. but probably this way is wrong.
And so I have thought to use Lorentz equation
$$F_{L,x}=q v_y B$$ $$ F_{L,y}=-q v_x B$$ $$F_{L,z}=0$$
but I don't know how I can obtain the center using this equation... what can I do?
Thank you so much!
If the electron moves in some direction at t=0, where is the center of the circle? In the direction of motion, behind it, left*, right*, something in between?
*as seen from "above" (positive z), for example
How can you find a point in that direction with a distance of R?
on the left? (negative charge move in anticlockwise..)
I have thought to use the euclidean distance between points, but I obtain only one relation and I don't obtain the coordinates of the center using the velocities.. can you help me? thanks a lot!
Hmm, let's view that from below, along the magnetic field. Ok, to the left, so at a 90°-angle to the direction of motion. Do you know how you can find an orthogonal line in 2 dimensions? The velocity components will help. And the euclidian distance will be used, too.
I'm not sure to have correctly understood your answer.
If I consider the line that have the direction of motion, I obtain
$$y-y_T=y'(x-x_T)$$
and the radius belongs to the line
$$y-y_T=-1/y'(x-x_T)$$
(y' is v_y, isn't it?)
and the euclidean distance between the position of the electron at generical istant t (x_T,y_T) and the center of the circumference (x_c,y_c) is
$$sqrt ((x_T-x_c)^2+(y_t-y_c)^2))=R$$
now I don't know what I have to do...
What is yT?
For simplicity, let's use x=y=0. You can add them afterwards.
If the velocity vector is (x',y'), can you find an orthogonal vector?
mfb said:
What is yT?
If the vector a=(a1,a2) si orthogonal to (x',y') then
a1*x'+a2*y'=0..
You can use this to generate some orthogonal vector. In 2 dimensions, there is a very nice way to chose a1 and a2.
  • · Replies 17 ·
