Projectile Motion - confirmation on answer(s) needed
The discussion centers on the calculations involved in projectile motion, specifically analyzing a marble rolling off a table with a horizontal velocity of 1.93 m/s from a height of 76.5 cm. The air time is calculated to be 0.395 seconds using the equation Δt = √(2Δdy/ay). The horizontal distance covered is determined to be 0.762 m, and the final vertical velocity is calculated as 3.87 m/s. The final velocity, combining both horizontal and vertical components, is confirmed to be 4.32 m/s at an angle of 63° above the ground, aligning closely with the textbook's rounded value of 4.3 m/s at 64° below horizontal.
  • Understanding of basic kinematics equations, specifically Δdy=ViyΔt + 0.5ayΔt²
  • Familiarity with projectile motion concepts, including horizontal and vertical velocity components
  • Knowledge of Pythagorean theorem and trigonometric functions for angle calculations
  • Ability to perform unit conversions, particularly between centimeters and meters
  • Study the derivation and application of kinematic equations in projectile motion
  • Learn about the effects of air resistance on projectile trajectories
  • Explore advanced projectile motion problems involving varying angles and initial velocities
  • Investigate the use of simulation tools like PhET Interactive Simulations for visualizing projectile motion
Students studying physics, educators teaching projectile motion concepts, and anyone interested in applying kinematic equations to real-world scenarios.
Element1674
"A marble rolls off a table with a horizontal velocity of 1.93m/s and onto the floor. The table is 76.5cm above the ground. Air resistance is negligible.
Find the horizontal distance, the air time and the final velocity."
Δdy=ViyΔt + 0.5ayΔt2
Rearranged: √(2Δdy/ay) = Δt *Equation A*
VconstxΔt=Δdx *Equation B*
Vfy2 = √(2ayΔdy) *Equation C*
Use equation A to find Δt, substituting in the variables gives 0.395 seconds. Therefore the ball was in the air 0.395 seconds.
Use equation B to find horizontal distance, substituting in the variables gives 0.762m [F]
Use equation C to find the final vertical velocity, which ends up being 3.87m/s [D]
Now since I know the final vertical velocity (3.87m/s downward) and the final horizontal velocity (1.93m/s [F], it remains constant since there is no air resistance) I can find the final velocity and its angle using pythagorean and trig.
The final velocity is 4.32m/s [63° above the ground] after those calculations. Is that correct? My textbook has 4.3m/s [64° below horizontal] which is oddly worded and doesn't seem to be the same.
The textbook just rounded to 1 decimal place, the value looks the same. The velocity is downwards, "below horizontal".
  • · Replies 21 ·
28K
