New Reply
Pressure Loss owing to multiple nozzles
Share Thread
Feb19-13, 12:30 PM   #1
Question
The following is the advancement of what I discussed in the link http://www.physicsforums.com/showthr...66#post4274966
Problem Statement
To calculate Pump Discharge Pressure, Calculate the wattage for the pump
Data :
  • Water @ 85 Degree C
  • Flow in for 24” pipe : 3010 m^3/hr
  • Flow in 8” pipe : 405 m^3/hr
  • Total length of pipe = 50ft
  • Nozzle Dia : 1"
  • Nozzle pressure : 100 psi
  • Nozzle Gallons per minute = 119
  • Number of Nozzles = 110 (placed equidistant along the length of the pipe)
  • Kinematic & Dynamic Viscosity of water can be found on : http://www.engineeringtoolbox.com/wa...ity-d_596.html
Is my approach (mentioned below) correct ?
Pump Discharge Pressure = Pressure Loss owing to flow thru Horizontal Pipe + Nozzle Pressure* Number of Nozzles
Then,
  • Find Reynolds Number
  • Determine if its turbulent or laminar flow?
  • Find the relative roughness of the pipe
  • Find the friction factor, either from Moody’s chart or Colebrook equation
  • Then calculate pressure loss = (fρLV^2)/(D*2) in Pascal
Now calculating Nozzle Pressure ,
  • Already given that per nozzle 100 psi. So total pressure loss owing to nozzles; is 100*110 and convert to Pascal units.
Then add ;
  • pressure loss (calculated above) with the Pressure loss owing to those 110 Numbers of nozzles...
    and, use the above addition and multiply with the flow rate to attain the wattage ?
Is this approach Correct ? Am I missing something ?
PhysOrg.com physics news on PhysOrg.com
>> Is there an invisible tug-of-war behind bad hearts and power outages?
>> Penetrating the quantum nature of magnetism
>> Rethinking the universe: Groundbreaking theory proposed in 1997 suggests a 'multiverse'
Feb20-13, 08:50 AM   #2
This above problem is somewhat similar to this one here discussed on http://www.physicsforums.com/showthread.php?t=353534
New Reply
Similar discussions for: Pressure Loss owing to multiple nozzles
Thread Forum Replies
Pressure drop across an array of different nozzles? Mechanical Engineering 2
Pressure loss calculation Classical Physics 1
pressure loss coefficient General Physics 1
Why is there a pressure loss with friction? Mechanical Engineering 8
Is pressure loss a good thing...? General Engineering 2
