Identifying trails in a Cloud Chamber
This discussion focuses on identifying particle trails in a cloud chamber, specifically targeting muons without the use of radioactive materials. Key characteristics of particle trails are outlined: thick, short tracks indicate alpha particles, while thin tracks with curves suggest electrons, and straight thin tracks correspond to muons. The curvature of the tracks reveals charge and energy information, while track length provides insights into particle lifetime. A significant magnetic field is necessary for accurate identification.
  • Understanding of particle physics, specifically muons and their properties
  • Familiarity with cloud chamber construction and operation
  • Knowledge of track characteristics in particle detection
  • Basic principles of magnetic fields and their effects on charged particles
  • Research the construction of cloud chambers and their operational principles
  • Study the properties and behavior of muons in particle physics
  • Learn about the effects of magnetic fields on particle trajectories
  • Explore techniques for analyzing particle decay and track branching
Amateur physicists, educators in particle physics, hobbyists building cloud chambers, and anyone interested in visualizing and identifying subatomic particles.
Sweeney
I was thinking of making a cloud chamber and have looked at several videos on them. I noticed several different types of trails and was wondering if anyone can identify which particles they belong to i.e. alpha, beta, muon. I'm am particularly interested in Muons and I won't be using any radioactive materials so background radiation is the only thing I need to be worried about. If it helps you can refer to this video .
Thanks!
Tracks are identified by deduction ... you know the basic properties of the different particles after all, so you can predict how they should behave in your device.
The curve of the track tells you the charge and gives clues about the energy.
The length of the tracks provide clues about the lifetime.
The way the tracks branch when a particle decays also gives clues about what decayed into what.
You also take steps to restrict what sort of particles you are likely to see.
As a rule of thumb:
thick, short tracks: alpha
thin tracks with curves or corners: electrons
thin tracks without curves and corners: muons
This needs a significant magnetic field.
Without a particle accelerator, most tracks should come from stable (or long-living, in case of muons) particles.
9K
