A bachleor's degree in mechanical engineering and a masters in idustri
The discussion centers on the decision to pursue a Bachelor's degree in Mechanical Engineering (B.S.M.E.) with a minor in Business Administration, followed by a Master's degree in Industrial Engineering (M.S.I.E.). This educational path is deemed reasonable as Industrial Engineering has a significant business focus, which complements the technical knowledge gained from Mechanical Engineering. While specific salary predictions are challenging due to variability, generally, obtaining a Master's degree leads to higher job offers compared to only holding a Bachelor's degree. The participant concludes that pursuing a Master's in Industrial Engineering aligns better with their career aspirations.
  • Understanding of Mechanical Engineering principles
  • Familiarity with Business Administration concepts
  • Knowledge of Industrial Engineering practices
  • Awareness of graduate program prerequisites
  • Research the prerequisites for Master's programs in Industrial Engineering
  • Explore the curriculum of Mechanical Engineering with a Business minor
  • Investigate career paths and salary expectations for Industrial Engineers
  • Learn about process modeling techniques used in Industrial Engineering
Students considering a career in Industrial Engineering, professionals evaluating educational paths in engineering, and anyone interested in the intersection of engineering and business administration.
Nael95sh
I want to become an Industrial Engineer,but for some reason i have to attend a specific college that only offers a masters degree in Industrial. What I want to know if it is a smart move to major in Mechanical engineer with a minor in Business Administration and then get a masters in Industrial. What are the advantages of doing so, and would the salary differ? OR should i just be satisfied with a Mechanical engineering degree?
note:mechanical engineering is my second choice.
I see three questions, so I will give you my best shot at answering them.
  1. Major in ME with a minor in Business
    If your goal is a masters in Industrial Engineering, this isn't an unreasonable path. IE has a bigger business focus than many other kinds of engineering. Have you looked at the pre-reqs for the IE program to be certain this will meet them?
  2. Advantages of #1 and salary
    IF you want to do what IEs traditionally do, which is model processes, and try to lean them out, then you will benefit from the technical knowledge of the ME degree and the linear modeling typical of an IE program. Your question on salary is hard to answer, because you didn't specify what you are comparing against. So I will just say, specific degrees or combinations of degrees do not predict salary well. The spread is large. In general, a job offer to someone with a Masters will be higher than someone with only a bachelors, all else equal. Elsewise I'm not sure what you mean here.
  3. B.S.M.E. only
    ME is a common and broad field. Work is available in this field, but of course I make no promises. If you want to be an IE, why don't you just pursue that degree and see what happens?
I guess ill pursue a masters degree in IE since it is more related to business and as you said it may versatile my career options.Thanks for your response.
  • · Replies 18 ·
  • · Replies 19 ·
