Bernoulli's Equation: Floating Ball
The discussion centers on applying Bernoulli's Equation, specifically the formula P1 + 1/2pv1^2 = P2 + 1/2pv2^2, to a project involving a floating ball. The user successfully identified the variables for atmospheric pressure (P1) but seeks assistance in determining the low pressure area (P2), mass, and pressure. Suggestions include using a barometer or thermometer to measure atmospheric pressure and calculating mass based on the identified volume for P2. This approach will facilitate the calculation of velocity (v2) at the low pressure area.
  • Understanding of Bernoulli's Equation and its components
  • Familiarity with fluid dynamics concepts
  • Knowledge of pressure measurement tools such as barometers
  • Basic principles of mass and volume calculations
  • Research methods for measuring atmospheric pressure using barometers
  • Explore fluid dynamics principles related to low pressure areas
  • Learn about calculating mass from volume in fluid contexts
  • Investigate the application of Bernoulli's Equation in practical scenarios
Students and professionals in physics, engineering, and fluid dynamics, particularly those involved in projects related to fluid behavior and pressure measurements.
smither777
Hi, I'm doing a project - Bernoulli's floating ball and i am trying to explain it using bernoulli's equation:
Where P1 represents the High pressure areas surrounding the jet air and the ball (atmospheric pressure) of which I have managed to obtain its variables.
It is the low pressure area (P2) which I have a problem with. I believe I can obtain the volume (for p) by presenting an orientation of which is a cylinder, but I don't know how to obtain mass and the Pressure itself.
I will use the equation to obtain the velocity (v2) at the low pressure area.
Can anybody help? Thanks.
Hi there! You're tackling a really interesting project! It sounds like you're making good progress so far. To obtain the mass and pressure of the low pressure area, you could use methods such as a barometer or a thermometer to measure the atmospheric pressure and then calculate the mass based on the volume you identified for P2. I hope this helps. Good luck with your project!
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 20 ·
