H/D Exchange: Why Minimum at pH 3?
  • Thread starter Thread starter Monique
    Exchange
The discussion centers on hydrogen/deuterium exchange experiments, specifically the observation that the exchange rate of hydrogen atoms reaches a minimum at pH 3. The protein is initially incubated at pD 7 and then quenched at pH 2-3. The kinetic isotope effect is highlighted, indicating that the activation energy for breaking deuterium bonds is higher than for hydrogen bonds due to the mass difference, which affects the rate of exchange. Lower pH levels correlate with reduced relative concentrations, impacting the efficiency of hydrogen formation.
  • Understanding of hydrogen/deuterium exchange principles
  • Familiarity with kinetic isotope effects
  • Knowledge of pH and pD concepts
  • Basic grasp of activation energy and reaction rates
  • Research the kinetic isotope effect in detail
  • Study the impact of pH on reaction kinetics
  • Explore the principles of collision theory in chemistry
  • Learn about equilibrium dynamics in chemical reactions
Chemists, biochemists, and researchers involved in protein studies and reaction kinetics, particularly those focusing on hydrogen/deuterium exchange methodologies.
Monique
Staff Emeritus
For a hydrogen/deuterium exchange experiment, the protein of interest is first incubated at pD = 7, after which it is quenched at pH = 2-3.
Why it the exchange done at a neutral pD and why has the exchange of hydrogen atoms a minimum at pH 3?
Chemistry news on Phys.org
This site pretty much explains the gist of it, there's probably a better explanation... nevertheless, here's the kinetic isotope effect
http://www.answers.com/topic/kinetic-isotope-effect
The lower the pH or pD the lower the relative concentration. According to the site, the activation energy for the breakage of a deuterium bond will be higher than the corresponding bond with hydrogen...due to the differences in mass of each, deuterium being heavier. Kinetic collision theory basically states that atoms collide, and this collision supplies the energy for the breakage of bonds (among other things), you can imagine that it'll be a bit more difficult to break the deterium bond.
Activation energy relates to the rate, the higher the energy, the slower the rate. If you wish to replace deuterium with hydrogen you'll need to increase the rate of formation of hydrogen; note that deuterium is not exactly stuck, it's in equilibrium.
The site also mentions subtle differences in electronegativity between the two in accounting for the kinetic isotope effect.
Probably not the best explanation, but hope it helps.
the hydrogen analog (compounds), in replacing deuterium with hydrogen
24K
