Simple experiment to measure atmospheric Oxygen
The discussion revolves around methods for measuring atmospheric oxygen levels, particularly in the context of a biology project. Participants explore various experimental approaches, including the use of steel wool and alternative volumetric methods, while considering the accuracy and feasibility of these techniques.
  • Experimental/applied
  • One participant describes a method using steel wool in a graduated cylinder to measure oxygen consumption through rusting, noting the need for a faster alternative.
  • Another participant suggests that there are established volumetric methods, such as the Winkler method, which could provide better accuracy for measuring oxygen levels.
  • A participant expresses a desire to focus on measuring oxygen in gas rather than dissolved oxygen in liquids, indicating a specific scope for their experiment.
  • One suggestion is made to pickle the steel wool in acid to enhance its reactivity with oxygen, potentially speeding up the reaction time.
Participants do not reach a consensus on the best method for measuring oxygen. While some propose established methods for accuracy, others advocate for the experimental approach using steel wool, leading to multiple competing views on the topic.
The discussion includes various assumptions about the methods proposed, such as the effectiveness of the steel wool and the modifications needed for established methods. There are also unresolved questions regarding the accuracy of the different approaches.
Individuals interested in experimental methods for measuring gas concentrations, particularly in biology or chemistry projects, may find this discussion relevant.
randi402
I am doing a biology project in which I needed to measure the O2 in the test chamber to determine how much activity I had. The Oxygen sensor I bought on eBay was long expired and useless. O2 instruments were at least $120 used. So I began looking for a simple cheap solution to do it with common items. One method I found was to put a small piece of steel wool (ultra fine 0000) at the base of a test tube, invert it in water, mark the tube, and wait till rusting consumed the oxygen. Then mark the new level and compare the volumes. That could work for me, but it takes several days to get a reading. I was hoping for something faster. I thought about the getters in vacuum tubes and wondered how those worked. Basically they use thin films of active metals and heat them with electromagnetic radiation to ignite the material. Well I have a microwave in my kitchen. An idea began to form.
1) I got a small graduated cylinder. I used a 10 ml cylinder. $5 ebay
2) some steel wool, very fine, and I found stretching it out into a yarn like spiral works best.
3) a bent soda straw
4) a microwavable glass container. A beaker would be perfect.
5) a kitchen microwave.
You take the steel wool and slide it to the bottom of the cylinder, leaving the spiral to run an inch down the tube. The fuzzier the wool sample the better it works. You fill the glass container with cold water. Place the short end of bent straw into the cylinder and invert it into the water. This next part is tricky. You need to suck air out through the straw till the water rises to the 10 ml mark (or the level you are using). You have to do this while the level of the water outside the cylinder is the same level as the water at your mark is. Otherwise the differential pressure will effect your reading. Also it's a very good idea to pour cold tap water over the cylinder into the container before you do this. This will give you a base temperature setting. Place the container with the inverted tube in the microwave. REMEMBER keep your sample of steel wool small. I used what would have been about the volume of three Que Tips stretched out. You want it to get hot and burn without shorting out your microwave. I found a series of three or four ten second shots were sufficient. Amazingly it doesn't leave burn marks in the tube. It will flash white and them burn orange for a moment. I think each shot let's more of the oxygen get up to the iron. Then take it out of the microwave and run tap water over the cylinder till the warm water in the container has all washed out and the cylinder and entrained air are at the original temperature. Now raise the cylinder till the inside and outside levels of water are the same and take your reading. I got 1.9 ml less or 19% oxygen. Clearly there is still a little O2 left to burn, and the volume of the steel wool reduces the volume of air, but within 10% isn't bad for a cheap experiment.
I am waiting on some nice Chinese all glass 100 ml syringes I bought on eBay for $10. This will allow me to suck samples from my test chamber, pinch the plastic sample tube with a non-conductive item, and do the whole experiment horizontally. I may not even need water, the piston in the syringe may pull down 21%.
Chemistry news on Phys.org
Drawing wouldn't hurt, just like splitting the text into paragraphs.
I have a feeling you are reinventing the wheel. There are good and cheap volumetric (titration) methods of determining the amount of oxygen (like Winkler method), and they will give you much better accuracy. You may have to modify the procedure as you are not dealing with the dissolved oxygen alone.
I'll check it out, though I'm not looking at dissolved oxygen levels in liquids. Everyone always complains about my paragraph lengths. I've never been able to get my arms around what I'm doing wrong. Maybe my wife can coach me. Thanks for the feedback.
Yes, that's why I mentioned you may have to modify the method. I believe it should be possible to reuse the chemistry, just modifying the procedure, to measure amount of oxygen present in the sample.
If you first pickle the steel wool in acid you'll give it an etched and unoxidized surface (reactive and many times the area it originally had), and you may find the reaction with oxygen proceeds almost as you watch, possibly within minutes. I can't comment on whether this may affect accuracy.
  • · Replies 26 ·
  • · Replies 19 ·
11K
  • · Replies 17 ·
9K
