Normally open switch & Normally closed switch.
  • Thread starter Thread starter pyroknife
    Closed Switch
The discussion clarifies the functionality of normally open (NO) and normally closed (NC) switches, emphasizing the distinction between latching and non-latching types. A non-latching NO switch only remains closed while the button is pressed, reverting to the open state upon release. In contrast, a latching NO switch maintains its closed state after being pressed, requiring another press to return to the open state. This differentiation is crucial for understanding switch behavior in various applications.
  • Understanding of electrical switch types: Normally Open (NO) and Normally Closed (NC)
  • Knowledge of latching vs. non-latching switch mechanisms
  • Familiarity with basic electrical circuit concepts
  • Experience with practical applications of switches in electronic devices
  • Research the differences between latching and non-latching switches in detail
  • Explore practical applications of Normally Open and Normally Closed switches in circuit design
  • Learn about the wiring configurations for NO and NC switches
  • Investigate the impact of switch types on circuit behavior and performance
Electronics enthusiasts, electrical engineers, and anyone involved in designing or troubleshooting circuits that utilize various types of switches.
pyroknife
This is not really a homework question. Just a question regarding the normally open (NO) and normally closed switches.
For an NO switch, if the button is pressed (not open anymore) and then the button is released, is the switch still in the "not open" state or does it go back to the open state?
Usually a Normally Open switch has contacts that connect only as long as the switch is operated (think of a doorbell button being pressed to ring a buzzer; spring action breaks the contact as soon as finger pressure is released).
I don't believe "an NO switch" is a sufficient description to answer the question.
I'd say it depends if the push button switch is a "latching" or "non-latching/momentary" type...
Non-Latching/momentary: Switch is closed only while the button is pressed. So when you release it the switch returns to the open condition.
Latching: Switch is open when the button is in the "out" position. When pressed the button moves to the "in" position and the switch is closed. When released the button stays depressed and the switch stays closed. When pressed again the button comes out and the switch opens.
The above describes a NO type but either can be NC or both (eg they have both NO and NC terminals).
