Why is acetic acid a weak acid?
  • Thread starter Thread starter cp255
    Acid Weak
The discussion revolves around the nature of acetic acid as a weak acid, particularly focusing on its solubility and dissociation in water. Participants explore the relationship between solubility and dissociation, as well as the implications for acidity in the context of chemical equations and equilibrium constants.
  • Some participants note that while acetic acid is soluble in water, it is classified as a weak acid due to its limited dissociation into ions.
  • Others argue that solubility and dissociation are distinct processes, emphasizing that a substance can be soluble without fully dissociating into ions.
  • A participant highlights the difference between polar molecules and ionic compounds, explaining that acetic acid can dissolve in water due to its polarity, even if not all molecules dissociate.
  • There is a correction regarding the chemical formulas of acetic acid (CH3COOH) and formic acid (HCOOH), with a focus on their monoprotic nature.
  • Some participants discuss the significance of equilibrium constants (Keq) in determining acidity, suggesting that the degree of dissociation is more critical than the number of protons released.
  • One participant expresses uncertainty about their previous statements but maintains that the general argument regarding acetic acid's dipole remains valid.
Participants generally agree on the distinction between solubility and dissociation, but there are competing views regarding the implications for acidity and the specifics of chemical behavior. The discussion remains unresolved on certain technical points.
Some limitations include potential misunderstandings about the definitions of acidity and the role of equilibrium constants, as well as the need for more rigorous language in the discussion.
cp255
So according to the rules of solubility all ionic compounds containing acetate are soluble in water. However acetic acid is a weak acid. Why is this if acetate is dissolved in water?
Chemistry news on Phys.org
Please elaborate, I am not sure where the problem is. Solubility and dissociation are two separate concepts (and separate processes). Just because something is well soluble doesn't mean it dissociates, just because something dissociates doesn't mean it is well soluble.
Probably all the acids you know are dissolved in water.
You are confusing "polar" with "ionic". If a molecule has an electric dipole, then it can dissolve in a polar liquid. If a molecule can dissociate into ions, then it can dissolve in a polar liquid. However, not all molecules with an electric dipole can dissociate into ions. Acetic acid happens to be able to do both.
A molecule doesn't have to dissociate to be dissolved. Glocose dissolves in water without dissociating because the molecule has an electric dipole. However, glucose doesn't dissociate into ions. NaCl can dissociate into ions. However, molecules of NaCl are unstable in water. Dissociation and solubility are two separate concepts.
The CH3COOH molecule is highly polar even if it doesn't associate. The H2COOH molecule has an electric dipole. Therefore, a solid made of H2COOH molecules will dissolve in polar liquids. Only some of the CH3COOH molecules will dissociate in water. When the molecule dissociates, in makes two H+ ions and one COO- ion. The number of H+ ions formed by dissociation determine whether a molecule is "acidic".
Darwin123 said:
Only some of the H2COOH molecules will dissociate in water. When the molecule dissociates, in makes two H+ ions and one COO- ion. The number of H+ ions formed by dissociation determine whether a molecule is "acidic".
I think you should double check yourself here. I'm not sure what molecule you're trying to denote but Acetic Acid (Ethanoic Acid) is CH3COOH and Formic Acid (Methanoic Acid) is HCOOH. Both are monoprotic acids.
Also acidity does not refer to the stoichiometric constants in the dissociation chemical equation but to the Keq/pKeq (or Ka/pKA because Chemists have to be difficult) of the dissociation chemical equation. The former being how I understood your post.
IE:
HX + H2O -> X- + H3O+ Keq = 10
H2X + 2H2O -> X2- + 2H3O+ This would happen in 2 steps but let's just say that the first step Keq_1 = 1/10 and the second let's say is the same Keq_2=1/10.
The strong acid is the first not the second even though the second yields two protons per dissociation while the first yields only 1. The degree of dissociation of the first is much higher than the second and therefore the first is the strong(er) acid.
IE:
Yes, you are right. Thanks for pointing it out.
My general argument is still correct. The CH3COOH has an electric dipole even before it dissociates. Therefore, it does not have to release hydrogen ions when it is dissolved in water. A few of the molecules do as determined by the pKa.
I am doomed !-)
I am doomed !-)
Yes you're general argument sounds okay and I actually like how you brought up glucose and NaCl examples, very clever.
In hindsight, my language was not very rigorous or specific really but I hope that people won't get confused and understand what I was trying to get at.
You are not doomed, I say stupid stuff on here all the time and get corrected by the pro's. Always learning, that why I love PF so much.
