Linear Algebra (Conditions for solutions).
The discussion focuses on the conditions for solutions of the linear system defined by the equations x + by = -1 and ax + 2y = 5. It establishes that if ab ≠ 2, there is a unique solution given by x = (5b + 2)/(ab - 2) and y = (5 + a)/(2 - ab). If ab = 2 and a ≠ -5, there are no solutions due to the inconsistency of the system. Conversely, if ab = 2 and a = -5, the system has infinitely many solutions, represented by the parametric equations x = 2t/5 - 1 and y = t.
  • Understanding of linear equations and systems of equations
  • Familiarity with augmented matrices and their interpretation
  • Knowledge of conditions for unique, no, and infinite solutions in linear algebra
  • Basic algebraic manipulation skills
  • Study the concept of linear independence and dependence in vector spaces
  • Learn about the Rank-Nullity Theorem in linear algebra
  • Explore the geometric interpretation of linear systems and their solutions
  • Investigate the use of matrix row reduction techniques for solving linear systems
Students studying linear algebra, educators teaching algebraic concepts, and anyone interested in understanding the conditions for solutions in systems of linear equations.
SherlockOhms
Consider the following system:
x + by = -1
ax + 2y = 5
Find the conditions on a and b such that the system has no solution, one solution or infinitely many solutions.
General Algebra really.
Previously we had been using augmented matrices to solve these sort of problems but using one here doesn't really help.
Rearranging the equations you get x = (5b + 2)/(ab - 2) and y =(5 + a) / (2 - ab)
The answer is:
If ab≠2 then the unique solution is x = (5b + 2)/(ab - 2) and y =(5 + a) / (2 - ab).
If ab = 2 and ab ≠ -5 then there are no solutions.
If ab =2 and a = -5 then x = 2t/5 -1 and y = t.
I understand why ab cannot be 2 for the first part of the answer but why is the fact that a can or cannot equal 5 when ab = 2 relevant for the second and third parts of the answer? Thanks.
x + by = -1
ax + 2y = 5
I used an augmented matrix.
The answer is:
The above should be - If ab = 2 and a ≠ -5[/color], then there are no solutions.
The reason for this can be seen in a reduced augmented matrix.
$$ \begin{bmatrix} 1 & b & | & -1 \\ 0 & 2 - ab & | & 5 + a\end{bmatrix}$$
If ab = 2, the bottom row is 0 0 | 5 + a.
If a = -5, the bottom row is 0 0 | 0, which implies that there are an infinite number of solutions. Geometrically, the system represents two lines that coincide.
If a ≠ -5, the bottom row is 0 0 <nonzero>, which makes the system inconsistent. Geometrically, the system represents two parallel lines that do not coincide, hence don't intersect.
If a
Brilliant. Thanks a million for that!
  • · Replies 19 ·
