Can mass spectrometry work on liquids and solids?
The discussion revolves around the applicability of mass spectrometry to liquids and solids, particularly in the context of different ionization techniques and methods used in mass spectrometry. Participants explore the mechanisms involved in analyzing samples in both states and the conditions required for effective mass spectrometric measurements.
  • Some participants note that mass spectrometry typically requires samples to be vaporized, while others mention that it can analyze liquids, particularly in liquid chromatography/mass spectrometry (LC-MS) setups.
  • One participant explains that mass spectrometry of solids can be achieved through techniques like secondary ion mass spectrometry (SIMS), where solids are bombarded with energetic ions to produce secondary ions for analysis.
  • Another participant highlights that liquids can be analyzed as gases, suggesting that the volatility of the liquid allows for this transition, especially in gas chromatography.
  • There is a mention of various ionization methods, indicating that the choice of technique may depend on the specific compounds being analyzed.
  • A participant references electrospray ionization as a method used in LC-MS, where dissolved substances are ionized without bombardment, raising questions about the state of the analytes during analysis.
  • Further clarification is sought regarding the state of molecules in liquid chromatography and their transition to vapor for mass spectrometric analysis.
Participants express differing views on whether mass spectrometry requires vaporization of samples, with some asserting that it can work with liquids directly through specific techniques. The discussion remains unresolved regarding the conditions under which mass spectrometry can effectively analyze liquids and solids.
Participants discuss various ionization techniques and their applicability to different states of matter, but there is no consensus on the necessity of vaporization for all mass spectrometric analyses. The discussion highlights the complexity of the topic and the dependence on specific methodologies.
ASidd
I am researching mass spectrometry for my school assignment and I seem to be getting contradictory answers. Some websites say that the sample used in mass spectrometry is definitely vaporized before use but other websites state that it can work on liquids e.g. in liquid chromatography/ mass spectrometry units? Which one is correct?
Chemistry news on Phys.org
The key point to recognise is that mass spectrometric measurements are carried out under vacuum conditions. In order to perform the analysis, the sample must somehow be turned into gaseous fragments.
Mass spectrometry of solids can most easily be achieved by bombarding the sample with energetic ions (e.g. Ar+). This causes the solid to emit so-called "secondary ions" (ionised fragments of the solid) which are then mass-analysed in a conventional mass spectrometer. This technique is known as secondary ion mass spectrometry or SIMS. SIMS is widespread in all kinds of applications, e.g. geology, semiconductors, and is known for its high sensitivity (<< 1 atomic layer).
Liquids are usually volatile enough to be analysed as gases (e.g. by allowing a small sample to expand in the ionization chamber). This is the approach used in gas chromatography (liquid is injected onto a hot filament, and vaporises). A technique related to SIMS, fast atom bombardment, is also used for mass spectral analysis (liquids of interest are mixed with the relatively involatile glycerine, for example).
But what happens in liquid chromatography? Are the molecules being analyzed not liquids?
Mass spectrometry relies on many different ionizing techniques to get a charged species. You should look into the different ionization methods to get more information. What works for certain compounds isn't necessarily the best technique for others.
I found this by googling mass "spectrometry ionization methods"
http://www.research.uky.edu/core/massspec/jeolioniz.pdf
In LC-MS when the dissolved substances leave the liquid chromatography unit, they are vaporized and then further ionized and analyzed in the MS.
  • · Replies 26 ·
  • · Replies 0 ·
