Finding the contraction formula using proper time
The discussion revolves around deriving the length contraction formula using proper time in the context of special relativity. Participants explore the implications of time dilation and the behavior of light in different reference frames, particularly focusing on a thought experiment involving a spaceship and light pulses.
  • One participant questions how to set up the problem of determining length contraction using proper time from the perspective of a stationary observer.
  • Another participant defines events related to the light beam's journey from the back to the front of the spaceship and provides coordinates for these events in different frames.
  • A participant emphasizes the need to derive the length contraction formula without using Lorentz Transformations, suggesting that time dilation can lead to this conclusion.
  • One participant proposes using a simplified Michelson-Morley apparatus to illustrate the time-dilation effect and its implications for length contraction.
  • There is a discussion about the assumptions that can be made regarding the constancy of the speed of light and the necessity of the principle of relativity in deriving results.
  • Another participant requests the exact wording of the problem to clarify the assumptions and conditions under which the derivation should occur.
  • Participants engage in calculations regarding the time intervals between events as measured in different frames, exploring the relationships between these intervals and the concept of proper time.
  • There are multiple calculations presented for the time intervals, with participants discussing the implications of these calculations for understanding length contraction.
  • One participant suggests rewriting the ratio of time measurements using the time dilation equation to relate it to length contraction.
Participants express differing views on the assumptions that can be made regarding the constancy of the speed of light and the use of Lorentz Transformations. The discussion remains unresolved as participants explore various approaches and calculations without reaching a consensus.
Participants highlight the importance of assumptions regarding the speed of light and the definitions of proper and improper time intervals. The discussion involves complex mathematical relationships that are not fully resolved, and the implications of these calculations for deriving the length contraction formula are still being explored.
robert Ihnot
If a passing spaceship sends a beam from the back to the front in their time of L/c andthen immediately the beam is reflected from front to back, can an stationary observer using proper time determine the length contraction formula?
I don't see how to set this up. Thanks for any help.
Let S' be the frame in which the ship is stationary, and let S be the frame where the ship's speed is v.
Define events:
E1, the light flashes
E2, the light is reflected
So the coordinates for E1 are:
x' = x = 0 and t'= t = 0
and the coordintates for E2 are:
x' = L and t' = L/c
x = Y(L +BL) = YL(1+B) and t = Y(L/c + BL/c) = YL/c(1+B)
(Y = gamma, B = beta)
So in S (the unprimed frame):
The distance between the two events is YL(1+B). But the ship moved between the time of the events a distance of vt. So the distance between the events is the length of the ship + vt. So:
the length of the ship (as measured in S) = x - vt
= YL(1+B) - YLB(1+B)
= YL*(1-B)*(1+B)
= L/Y
That is all well and good, but the problem was in the book prior to defining the Lorenz Transformation. The idea is that knowing about time dialation, can you derive the formula for length contraction? The spaceship involves three events. The light beam is sent from the back, it reaches the front end of the ship and is reflected, it returns to the back of the ship.
Here's a proof using a moving simplified Michelson-Morley apparatus (two light clocks).
Along the transverse direction, you will derive the time-dilation effect.
Along the longitudinal direction, you argue like this:
in order for the round-trip time to be the same in both directions (as required by the principle of relativity when compared to a similar apparatus at rest), the length along the longitudinal direction must be contracted.
robphy,
But he says you can't use the Lorentz Transforms. And the "principle of relativity" is necessary and sufficient for the LTs being true. So you can't use the principle of relativity.
robert Ihnot,
Your two posts don't seem to be asking for the same thing. In the first one you don't say anything about knowing the time dilation formula. And you never say whether we can assume the speed of light is constant or what (if anything) the stationary observer measures or finds out about the spaceship experiment.
You need to give us the EXACT wording of the problem in your book and any assumptions that we can or can not make.
"Special Relativity" implicity involves Lorentz Transformations.
Using the LTs explicitly is one way to obtain results in SR.
However, at this point, the student does has not seen the LTs explicitly.
So, using a thought experiment (as I've described), one can obtain the length-contraction effect using algebra and geometry [which is consistent with using the LTs, when it is introduced].
jdavel: robert Ihnot,
The author, Leo Sartori has already gone into the use of clocks and that the speed of light is observed as a constant by all observers. He makes the point that knowing time dilation, one can deduce length contraction.
I might add it seems then that robphy: Along the transverse direction, you will derive the time-dilation effect. Along the longitudinal direction, you argue like this:in order for the round-trip time to be the same in both directions (as required by the principle of relativity when compared to a similar apparatus at rest), the length along the longitudinal direction must be contracted. This sounds like the right idea, but I would like more detail.
Here is the problem: "A spaceship whose length in its own rest frame is L(0) moves at velocity V relative to the earth. Let L be the length of the spaceship as measured in the Earth's rest frame, S.
(A) A light pulse emitted at the rear of the spaceship (event E(1)) arrives at the front (event E(2)). In the spaceship frame, S', the time interval between E(1) and E(2) is t'-t'(1) = L(0)/c. Find the time interval between the same two events in frame S, in terms of L, V, and c. (Note that this time interval is not proper* in either frame. Picture** is mentioned.)
(B) The light pulse is reflected and arrives at the rear of the spaceship (event E(3)). Find the time interval between E(2) and E(3) in frame S.
(C) Applying a proper* time argument to the interval between E(1) and E(3), show that L and L(0) are related by the length contraction formula L= L(0)/Y" (where Y represents gamma as used in jdavel's example.)
*"An interval between events that happen at the same place is called a proper time interval. Any other interval is called improper.
** The picture refers to three diagrams describing the rays in Michelson's experiment. One horizontal, one vertical, and one along a diagonal.
robertIhnot,
Ok, I see what he wants.
You can assume that the speed of light (in either direction) as measured in either S or S' is always the same, namely it's c.
So, for part a) The time interval between E1 and E2 as measured from the Earth frame will just be the distance the beam travels divided by the speed of the beam. So, the denominator of the fraction is, of course, c. Now you get to do the hard part. What's the distance (measure from earth) that the light beam travels to get from the back to the front of the ship?
Hint: First it has to get to where the front of the ship was when it started traveling forward from the back. How long will that take? Then it has to go a little further because the front of the ship moved during that time.
jdavel: Now you get to do the hard part. What's the distance (measure from earth) that the light beam travels to get from the back to the front of the ship?
The beam would have to travel L (as measured in the Earth Frame + Vt, where t is the time it takes the beam to get there. So, starting from 0 in the stationary system, we have ct = L+Vt, which gives us
t =L/(c-v).
robertIhnot,
That would be hard if I didn't have your answer!
But as the light goes back, the back of the ship is coming forward to meet it at just the speed it was going away from the beam in your calculation. You found the time between E1 and E2 (measured from the earth) is:
t(1,2) = L/(c-v)
so
t(2,3) = L/(c+v)
Now it's your turn again.
What's t(1,3) as measured in the Earth frame?
The notation is a little confusing, but the time of the total trip is L/(c-v) + L/(c+v)=
[tex]\frac{2Lc}{c^2-v^2}[/tex]
robertIhnot,
Sorry about the notation; t(n,m) is the time (measured in S, the Earth rest frame) between events En and Em.
So you got:
t(1,3) = 2Lc/(c2 - v2) (clumsy notation again, but you know what I mean!)
Dividing the top and bottom by c2 first will make the next step easier:
t(1,3) = (2L/c)/(1 - v2/c2)
Your turn. Divide this equation by the equation for t'(1,3) (the proper time between E1 and E3, measured on the space ship) and look what you get!
The time measured on the ship is 2L(0)/c, so division yields [tex]\frac{L(1-(v/c)^2)}{L_0}[/tex]
robertIhnot,
So that's equal to the ratio of the two time meausrements. But remember, the problem said that "...knowing time dilation, one can deduce length contraction". So rewrite the ratio of the times using the time dilation equation and set that ratio equal to what you just calculated.
Edit: I think you have an error in your ratio. Either the L and L(0) need to be reversed or the other factor needs to be in the denominator. Right?
Yes, thank you. I did have that inverted some how:[tex]\frac{2L/c)}{1-(v/c)^2} *\frac{1}{2L_0/c} =\frac{L/L_0}{1-(v/c)^2}[/tex]
Since the ratio T/T' = [tex]1/\sqrt{1-(v/c)^2}[/tex] We can set the two terms equal giving [tex]L=L_0\sqrt{1-(v/c)^2}[/tex]
Thus going back to the original problem: "A spaceship whose length in its own rest frame is L(0) moves at velocity V relative to the earth. Let L be the length of the spaceship as measured in the Earth's rest frame, S."
Thus, the interpretation is that we measure this same spaceship as shorter than measured in its own rest frame.
jdavel, thanks very much for your help!
robert,
You're welcome.
One last thing. The calculations you did required that the speed of light you used to find the time interval between E1 and E3 in the Earth frame was the same as the one used to find the time interval in the spaceship frame. In both cases it was c. Be sure you see how important that was in getting the result; just assuming length contraction wouldn't have been enough.
jdl
  • · Replies 63 ·
  • · Replies 54 ·
  • · Replies 52 ·
  • · Replies 29 ·
  • · Replies 45 ·
  • · Replies 31 ·
