| Thread Closed |
force on each wall of a box |
Share Thread | Thread Tools |
| May4-05, 02:08 PM | #1 |
A cubic metal box with sides 32.0 cm contains air at a pressure of 1.00 atm and a temperature of 294 K. The box is sealed so that the volume is constant and it is heated to a temperature of 396K. Find the force on each wall of the box due to the increased pressure within the box. [The outside air is at 1 atm of pressure.]
I started out PV=nRT volume of the box = .32^3=0.328m^3*(1L/1x10^-3)=32.8L n=PV/RT 1atm(32.8L)/(.08207 atm L/mol*K)(294K)=1.36mol P=nRT/V [1.36mol(.08207 atm L/mol*K)396K]/32.8L =1.35 atm F=P*A =1.35 atm*.32^2=.138 **that isnt the correct answer |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| May4-05, 02:20 PM | #2 |
Recognitions:
There is no need to calculate n, since it is constant, but it is not wrong to do so. Assuming your calculation of the pressure is correct, it looks like you have just neglected to account for the 1atm pressure still on the outside.
| May4-05, 02:26 PM | #3 |
how do you account for that?
| May4-05, 02:29 PM | #4 |
Recognitions:
| May4-05, 02:42 PM | #5 |
F=deltaP*A .35*.32^2=.03584 that came up as incorrect |
| May4-05, 03:13 PM | #6 |
Recognitions:
| May4-05, 03:56 PM | #7 |
Your whole numerical computations need to be redone,as they're wrong...The volume of the box,for example
[tex] V_{\mbox{box}}=(32\cdot 10^{-2}\mbox{m})^{3}=2^{15}\cdot 10^{-6}\mbox{m}^{3}=32.784\cdot 10^{-6}\mbox{m}^{3}\simeq 32.8\cdot 10^{-3}\mbox{m}^{3} [/tex] Use SI-mKgs units... Daniel. |
| May4-05, 04:57 PM | #8 |
Recognitions:
Like Dex said...units!!!!
Since you are working in SI units, your volume must be in meters and your pressure must be in Pa (n/m^2). Only then will your answer be in Newtons. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: force on each wall of a box
| average force exerted on ball by wall at angle | Introductory Physics Homework | 2 | ||
| Get into the wall !!! | Atomic, Solid State, Comp. Physics | 2 | ||
| thick wall or thin wall ? | Biology | 3 | ||
| Wall Climbing Force Problem | Introductory Physics Homework | 5 | ||
| Impact of a car on a wall | General Physics | 20 | ||
