How Is Transverse Tensile Strength Measured in Micron-Sized Fibers?
Transverse tensile strength in micron-sized fibers, such as carbon fibers, is not typically measured directly. Instead, properties are derived from lamina properties to eliminate the need for measuring composite constituent properties. For single fibers, unidirectional tensile testing is conducted according to ASTM D3379 standards, which provides a reliable method for assessing tensile strength in these materials.
  • Understanding of transverse and longitudinal tensile strength
  • Familiarity with ASTM D3379 testing standards
  • Knowledge of composite materials and lamina properties
  • Basic principles of fiber mechanics
  • Research ASTM D3379 testing procedures for unidirectional tensile testing
  • Explore the concept of lamina properties in composite materials
  • Study the mechanical properties of carbon fibers and their applications
  • Investigate methods for measuring transverse tensile strength in other materials
Materials scientists, engineers working with composite materials, and researchers focused on the mechanical properties of fibers will benefit from this discussion.
RGClark
How is tranverse tensile strength defined? How is it measured for thin fibers?
Some high strength fibers such as carbon fibers have longitudinal tensile strength of 1,000,000 psi. But these fibers have diameters that measure in the microns. How could a transverse tensile strength be measured in that case?
Bob Clark
I'd say they're not measured ... you work with lamina properties and this way eliminate the 'need' to work with composite constituent properties. What is & can be done for single fibers is unidirectional tensile testing, for example according to ASTM D3379.
9K
