Calculating Speed of Block-Spring Collision w/Kinetic Friction
The discussion focuses on calculating the speed of a block at the moment of collision with a spring on a horizontal surface, factoring in kinetic friction. The conservation of energy principle is applied, leading to the equation .5kx² = .5mv² + μmgx, where μ represents the coefficient of kinetic friction, m is the mass of the block, g is the acceleration due to gravity, and x is the compression distance of the spring. The frictional force affects the energy balance, necessitating its inclusion in the calculations to accurately determine the block's speed.
  • Understanding of conservation of energy principles
  • Familiarity with kinetic and potential energy equations
  • Knowledge of frictional force calculations, specifically F_{fr} = μN
  • Basic mechanics of springs and Hooke's Law
  • Study the derivation of the work-energy principle in mechanics
  • Learn about the effects of friction on motion and energy loss
  • Explore advanced spring dynamics and oscillation equations
  • Investigate real-world applications of kinetic friction in engineering
Physics students, mechanical engineers, and anyone interested in understanding the dynamics of block-spring systems with frictional forces.
bullroar_86
one more spring question :smile:
A block collides with a spring on a horizontal surface
the block compresses the spring x metres from rest position. What was its speed at the instant of collision
Ok so far I know how to do this question
Ee = Ek
.5kx^2 = .5mv^2
but in this question there is a coefficient of kinetic friction between the block and the surface.. not sure how it fits in.
I'm thinking that it is only affecting the Ee part of the equation..so:
Ee = Ek
.5ukx^2 = .5mv^2
is this right?
Well, you can still use conservation of energy, only you have to take into account the work done against friction as well. The friction is a constant force, so things are kept simple.
Do you know [tex]F_{fr} = \mu N[/tex], to relate the frictional force to the normal force of the surface on the block ? N, is of course, equal to the weight of the block considering that this is a horizontal surface.
The work done against friction is [tex](F_{fr})(x)[/tex], since x is the distance moved in the direction of the force.
Then just use conservation of energy :
Initial energy of system = Final energy of system
Initial KE of block = Work done against friction (dissipated as heat to surface and block) + Potential Energy stored in spring.
[tex]\frac{1}{2}mv^2 = \mu mgx + \frac{1}{2}kx^2[/tex]
and express v in terms of [itex]\mu[/itex], m, g, k and x.
Yes, you are correct in thinking that the coefficient of kinetic friction will affect the calculation. In this case, the energy lost due to friction will need to be taken into account in the equation. So the correct equation would be:
Ee = Ek + Ef
where Ee is the elastic potential energy, Ek is the kinetic energy, and Ef is the energy lost due to friction. So the equation would be:
.5kx^2 = .5mv^2 + uFn
where u is the coefficient of kinetic friction and Fn is the normal force. From here, you can solve for v to find the speed of the block at the instant of collision. Keep in mind that the normal force will also need to be calculated using the weight of the block and the angle of the surface. I hope this helps!
  • · Replies 16 ·
  • · Replies 58 ·
  • · Replies 16 ·
