Thickness between glass plates
The discussion focuses on the visibility of interference patterns between two glass plates based on their separation thickness. It concludes that interference patterns are observable when the gap is on the order of a few wavelengths of light, typically less than 1mm. The coherence time of the light source plays a critical role in the visibility of these patterns, with laser sources providing longer coherence times than non-laser sources. The user seeks to understand the relationship between gap thickness and the visibility of interference patterns, particularly in relation to coherence length.
  • Understanding of interference phenomena in optics
  • Knowledge of coherence time and coherence length
  • Familiarity with light wavelength and its measurement
  • Basic principles of laser and non-laser light sources
  • Research the concept of coherence time in detail
  • Explore the relationship between gap thickness and interference visibility
  • Study the differences between laser and non-laser light sources
  • Investigate practical experiments demonstrating interference patterns
Students and professionals in optics, physicists studying wave phenomena, and anyone interested in the practical applications of interference patterns in glass plate setups.
jetpeach
Hi, I generally understand interference and Newton's ring/Young's double slit experiments, but I can't find the answer to a pretty simple question:
When two glass plates are placed together and their is a gap of thickness "t", contructive and destructive interference leads to interference patterns as described http://physics.bu.edu/~duffy/PY106/Diffraction.html
but at what thickness will these patterns no longer be visible, at least by eye? Basically, I find tons of things saying, "from the inner and outer surface of a bubble light is reflected and interfers... and patterns show depending on m*lambda... " But at what upper limit of the integer wavelengths of light does this stop? If you have two glass plates 1cm apart, clearly you don't see interference due to the gap between them, but what about 1mm? 100um?
Basically, one of my advisors states that because we can see interference patterns between our glass plates, they are separated by at most a few wavelengths of light, but I'm wondering why or how this is the case and if I can prove it. Thanks for any help! Be back in the morning to follow up,
jet
Science news on Phys.org
The presence of the interference pattern also depends on a radiation source. Because of reflections from different spots, the reflected waves reach an observer with a time delay. So the source should keep its phase during that time interval.
Usual non-laser sources have very short coherence time, so we cannot see any coherence if interfering waves arrives with a delay of several periods. Lasers, on the other hands, can keep their coherence longer, so we can see an interference pattern resulting from reflections from more separated surfaces. Now there will be another problem- to keep the distance constant with a precision better then wavelength.
thanks
Ahhh, coherence time (and length) seem to provide be the answer to my question.
just if anyone else is interested
http://www.physlink.com/Education/AskExperts/ae372.cfm
http://www.absoluteastronomy.com/encyclopedia/C/Co/Coherence_length.htm
Thanks much, jetpeach
  • · Replies 17 ·
11K
9K
