Can XP Be Installed on a Computer with Windows ME?
  • Thread starter Thread starter z4955
    Computer
The discussion revolves around the feasibility of installing Windows XP on a computer that originally came with Windows ME, including considerations about upgrade paths and system requirements.
  • Some participants suggest that the original Windows ME installation is necessary to use an upgrade disk for Windows 2000.
  • There is uncertainty about whether a Windows 98 restore disk can be used to format the computer before upgrading to Windows 2000.
  • One participant mentions that Windows XP could potentially work on the computer, depending on its specifications, citing a specific example of a 450MHz machine with 128MB of RAM.
  • Another participant discusses the challenges of performing a remote install of Windows 98 and the limitations of copying an OS from one machine to another.
  • There are suggestions about using DOS commands or alternative operating systems like Linux for formatting the disk.
  • A participant indicates that after some troubleshooting, they were able to repair their Windows 2000 installation, which raises questions about the necessity of reverting to Windows ME.
  • One participant expresses a preference for Windows XP, suggesting it is a better option despite the ongoing discussion about installation challenges.
Participants do not reach a consensus on the best approach to install Windows XP on a computer that originally had Windows ME. Multiple competing views and uncertainties remain regarding the upgrade process and system requirements.
Participants mention various upgrade paths and the necessity of having the original operating system for certain installations, but there are unresolved questions about the specifics of these processes and the hardware requirements for Windows XP.
z4955
I'm having probs reformatting a computer with win 2000
every time I put the win 2000 disk into install windows I a gray box comes up: this installation must be installed to run. Plz run Setup fron the location where is originally installed the application
Computer science news on Phys.org
So you got it to boot properly now? If so, you must have one of those upgrade disks and not a full install cd.
it was upgraded from win ME to win 2000
so you mean I can't reformat the computer with this cd?
I'm not too familiar with upgrade disks but probably not. You'll need to get a hold of a full version copy.
so in order to reformat the computer I need to reformat it with windows ME and then upgrade it with the win 2000 cd?
If it is an upgrade cd then you need to install a previous version first. So yes.
the original win ME restore cd that came with the computer is lost. how can I get another one... or can I use one from the other computer which is win 98? Then upgrade to win 2000 from 98?
Didn't you see my PM?
I suggest that you just go out and buy XP...you caveman...it's way better despite what anyone says.
will xp install and perform properly on a machine that came with win ME?
dduardo: I saw your pm, but my question was can I format and install win 98 from another computer to the computer I'm having probs with that came with win ME and was upgraded to win 2000
1) xp could work, but it depends on the computer's specs. I know XP runs fine on a 450Mhz computer with 128MB of ram.
2) I don't think you can do a remote install with win98.
You could do some DOS "deltree" command to delete the disk. I don't know how thorough it is though. You could also install Linux. When I recently installed Linux, it easily formatted my disk for me.
I agree with dduardo, I don't think it is possible to copy an entire OS from your computer and send the file over to another computer. Many things have to be installed and can't simply be copied.
Can you further explain what happens when you put the installation disk in?
the win 2000 disk wasn't a bootable disk the reason it wouldn't boot so I had to create startup boot floppies and then finally got to the setup mode. Instead of reformatting, it gave an option to do a repair which I did and it is working a lot better now. I downloaded and installed avg and spybot both of which would not install before. avg discovered and got rid of some viruses and now it seems to be working ok.
fyi
I think u can, most pxe enviroments are dos based, not to mention most enterprise clone software uses dos to perform any cloning of an os that can be distrubuted across a network...
however within the context I understand the question came from, you were right, I don't thnk you can mount a win98 cd across a netwrk
I wasn't asking if you could install an OS over a network or from one computer to another. My question was, "can xp be installed in a computer that came with windows me?" I now understand that it can, but needs more memory to run properly.
  • · Replies 38 ·
