Discover the Maclaurin Series for f(x) with Derivative Calculations
The discussion revolves around finding the Maclaurin series for the function f(x) = (1+x)^(1/2) – (1-x)^(1/2). Participants explore methods for calculating the series and its derivatives at specific points, particularly f ^5 (0) and f ^20 (0).
  • Homework-related, Mathematical reasoning
  • One participant presents their approach to finding the Maclaurin series and expresses confusion over discrepancies in derivative calculations.
  • Another participant questions the solvability of the problem and seeks advice.
  • A third participant suggests that the question might be more appropriately categorized in the homework section and recommends focusing on the nth derivative of the series.
  • A fourth participant proposes simplifying the problem by separating f(x) into two functions, g(x) and h(x), and finding the Maclaurin series for each before combining them.
There is no clear consensus among participants. Various methods and approaches are suggested, but no agreement is reached on the best way to solve the problem or on the correctness of the initial calculations.
Participants express uncertainty regarding the correctness of derivative calculations and the overall approach to finding the Maclaurin series. There are also indications of missing assumptions or steps in the calculations presented.
defang
My question is as follows: Let f (x) = (1+x)^(1/2) – (1-x)^(1/2). Find the Maclaurin series for f(x) and use it to find f ^5 (0) and f ^20 (0).
I got: X + Riemann Sum { [ (-1)^(n-1) 1x3x5**x(2n-3) ] / (2^n) x n!} X^n (after combining two Riemann Sums together). And I got (7!5!) / 16 5! = 315. However, I tried to check my answer by taking derivative 5 times, and I got 105/16. Can anyone tell me what I did wrong? thanks
Is this question unsolvable? Or is it .....? Please, somebody gives me some advice....
This really should be put in the homework section, but anyway, I can't tell you what you have done wrong but it'd probably be much easier to try and work out the nth derivative of the series, or at least the nth derivative at x = 0.
hello there
if I were you I will try to make the problem look more simpler, why don't you split the function, like f(x)=g(x)-h(x) where
h(x)=(1-x)^(1/2) and
g(x)=(1+x)^(1/2)
find the maclarin series for each h(x) and g(x) then find the maclarin series for f(x)
and as for the last parts f^n(x)=g^n(x)-h^n(x) this should most likely work
steven
  • · Replies 48 ·
