Thread Closed
eigenfunctions and eigenvalues
Share Thread Thread Tools
Jul11-05, 09:19 PM   #1
This is probably a straight forward question, but can someone show me how to solve this problem:
[tex]
\frac {d^2} {d \phi^2} f(\phi) = q f(\phi)
[/tex]
I need to solve for f, and the solution indicates the answer is:
[tex]
f_{\substack{+\\-}} (\phi) = A e^{\substack{+\\-} \sqrt{q} \phi}
[/tex]
I know I've covered this before - just need a refresher on how to solve.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Jul11-05, 10:19 PM   #2
One way to solve this problem is to "guess" a solution. Since the form of your equation is very basic, this guess is usually taught as a standard method.
As your solution suggests, your guess should be the following:
[tex]f(\phi)=e^{r\phi}[/tex]
Simply replace every function f with that equation above and solve for the unknown, r. Then, once you find r, plug it back into the equation above. Note that the "A" in your answer is an arbitrary constant used to solve with initial conditions.
Jul11-05, 10:34 PM   #3
thanks - knew it was something simple. I actually remembered the other approach too, where you replace f'' with r^2, f' with r, and f with 1, and then solve for what r is. But either approach gives the same result.
Thanks again though.
Jul11-05, 11:11 PM   #4
An additional question, somewhat related:
When determining the eigenvalues, the problem indicates that
[tex]
f (\phi + 2\pi) = f (\phi)
[/tex]
Given the answer already shown, why would this periodic function require:
[tex]
2 \pi \sqrt{q} = 2 n \pi i
[/tex]
Jul12-05, 12:41 AM   #5
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Take your given condition and substitute in the solution that has been found. Write the exponent of a sum as a product of exponents and the desired result follows automatically.
Do it. If you have trouble, show us what you tried and what part is bothering you.
Jul12-05, 12:17 PM   #6
Nevermind, I got it now - didn't realize the relation between 1 and e^(i2n(pi))....
[tex]
A e^{\sqrt{q} \phi} = A e^{\sqrt{q} \left( \phi + 2 \pi \right)}
[/tex]
[tex]
e^{\sqrt{q} \phi} = e^{\sqrt{q} \phi} e^{\sqrt{q} 2 \pi}
[/tex]
[tex]
1 = e^{\sqrt{q} 2 \pi}
[/tex]
[tex]
e^{i 2 n \pi} = e^{\sqrt{q} 2 \pi}
[/tex]
[tex]
i 2 n \pi = \sqrt{q} 2 \pi
[/tex]
[tex]
i n = \sqrt{q}
[/tex]
[tex]
q = -n^2 (n=0,1,2....)
[/tex]
Thread Closed
Thread Tools
Similar Threads for: eigenfunctions and eigenvalues
Thread Forum Replies
Eigenfunctions & Eigenvalues Advanced Physics Homework 1
Eigenvalues and eigenfunctions of the lowering operator Advanced Physics Homework 2
Eigenfunctions and their Eigenvalues Calculus & Beyond Homework 4
Angular Momentum, L_x eigenvalues and eigenfunctions Advanced Physics Homework 1
Eigenfunctions and eigenvalues of Fourier Transform?.. Calculus 4
