Dr.Brain
- 539
- 2
The Real Statement
The actual path between two points taken by a beam of light is the one which is traversed in the least time.
Modern Restructured Statement
To travel from one point to another ,Light would choose the path such that all other paths nearby take almost exactly the same time.
Although from my readings I have found that this law explains majority of the light phenomena's like reflection, refraction and interference.Reflection and refraction studied by the geometrical optics and interference studied through wave character of light, and each of these phenomena are studied using different light-spectrum components , interference can be best studied through radiowaves , and reflection/refraction through lights with smaller wavelengths.And all of these light phenomena have closely followed the F.P which has further predicted new things.
The modern statement says that the light ray will choose a path with minimum obstructions (as in refraction), and will take a path such that all other paths nearby take similar exact time.So is it that light sorts of smells and checks other paths against each other? and then finally selects the correct path. The modern statement also asserts that "If light wants to choose the path which will take the least time to reach the destination, the path may not be the shortest'.
Lets say we take a radiowave-source , a detector and a slit-setup as in the diagram, when the detector is at S , the light simply takes the smallest path and travels straight to S when slight is wide , now when slit is narrowed , S is further illuminated (correct me if I am wrong) . Now let's widen the slit again and move S to S' , Now light won't reach S' properly (because all other paths nearby take different times), now when we narrow the slight again , more light reaches S' because as I said before they sort of sense that now only one path is available and that is through perfectly narrowed slit and they would take it! . So what does this experiment tell us? It tells us that light still reached S' , so light need not travel always in straight lines.
Q.1. Now what does Fermat's Principle has to say about 'narrowing off slit' helped more light reaching S' , but when the slit was wide , light had more options , and if it had correctly sensed the paths , they all take similar times' don't they?
Q.2 Nature always acts by the shortest and simplest path, is only a moral principle, not a physical one—it is not and can not be the cause of any effect in nature
Principle
BJ
Principle
BJ
