Adjustment of optics resources
  • Context: High School
  • Thread starter Thread starter silin
    Optics Resources
The discussion revolves around the adjustment of optical components, specifically focusing on techniques for aligning lasers and lenses in optical setups, including a self-made confocal microscope. Participants seek advice on ensuring proper alignment to minimize aberrations and improve performance.
  • Homework-related
  • One participant inquires about resources for adjusting optical components, particularly for ensuring light is centered on lenses to avoid aberrations.
  • Another suggests looking into manufacturer catalogs for optical components and highlights the importance of considering the type of light source, such as lasers, which have specific adjustment rules.
  • A participant specifies their use of Linos microbench and Owis optical rail mounts and expresses interest in confocal microscopy adjustments, seeking further resources.
  • Links to external resources on confocal microscopy are shared, with an invitation for specific questions about optical alignment.
  • Concrete questions are posed regarding ensuring laser beam parallelism, centering beams in the microbench system, measuring beam diameter, and achieving precise angles with mirrors.
  • One response provides a method for ensuring the laser beam is parallel by measuring heights at different points along the beam path.
  • Another suggests using a CCD array for accurate beam spot measurements and discusses methods for ensuring a mirror reflects at a right angle.
  • A participant asks how to ensure a parallel laser beam passes through the center of a convex lens without advanced equipment, sharing their current method of projecting the beam onto a wall.
  • A response outlines a method for aligning the lens based on the deflection of the beam and emphasizes the importance of a good lens mount.
Participants express various methods and techniques for optical adjustments, but no consensus is reached on specific practices or solutions. Multiple competing views and approaches remain in the discussion.
Some methods discussed depend on the specific optical setups and may not apply universally. Limitations include the lack of consensus on the best practices for certain adjustments and the reliance on specific equipment.
silin
Hi everyone,
who knows where to find a good introduction into adjustment of optical components, like making sure that light correctly centered on a lens, so that there are no aberrations, adjustment of mirrors under certain angles and such. I've been looking for some advice on adjustment, but couldn't find it on this general level. Did anybody see such stuff in books or on the web somewhether. I'll be very very thankful.
Science news on Phys.org
How you adjust an optical component depends on the mount. I suggest looking up various manufactureres of optical compoenents and mounts, for example Thor Labs, Melles Griot and Spectra Physics have product catalogues that cover this kind of thing, although I'm not sure how much of the catalogue is available online.
Also, are you using a laser as your light source? Laser optics follows different rules (especially safety rules) to other types of optics.
Claude.
Thank you for the reply. The mounts I´m using are microbench (Linos) and optical rail (Owis). I´ve checked the manufacturers you mentioned, only Melles Griot has some about laser beam positioning. I do use laser light. I´m actually specifically interested in adjustment of a self-made confocal microscope. Does anybody know any sources about that? Thanks.
I googled confocal microscopy and found a few interesting sites, including this one;
http://www.physics.emory.edu/~weeks/confocal/
The links in particular I think are worth having a look at. If you have any specific questions about aligning optics, post them here and I'll try to answer them as best I can.
Claude.
I have a couple of concrete questions by now:
- how to ensure that laser beam is exactly parallel to the edge of the optical table?
- what are the options of centering the beam in Linos microbench system (I know about using a quadrant photodiode, iris diaphragms or pinholes in the light path, are there other options?)?
- how to measure laser beam diameter except for marking on paper how broad it is (seems like not really exact)?
- when you bend a beam with a mirror, how to make sure that the angle is exactly 90 degrees?
Thanks in advance.
To ensure the beam is parallel to the table, simply measure the height of the beam and two different points along the path. Adjust the laser beam until the heights at two different points match. Obviously, the further apart these two points are (in terms of beam path length) the more accurate your alignment will be.
I am not familiar with the Linos microbench system unfortunately, so I can't really answer your second question.
Accurate beam spot measurements are done using a CCD array similar to what you would find in a digital camera. With a CCD array, each CCD acts as a detector, representing a single pixel on an image. From there it is just a matter of extracting the numerical data and performing whatever analysis you require.
The easiest way to ensure a beam is bending at a right angle, is to measure a 90 degree angle and align the beam to where you think it ought to be. If you have some way of ensuring you have a surface that is exactly parallel to the incident beam, you can get fancy and use interference patterns to align the mirror (provided the mirror is only partially reflecting).
Claude.
Thank you, Claude. I have one more question: does anybody know how to make sure that a parallel laser beam goes exactly through the center of a convex lens without having a CCD camera or any fancy laser profile monitor? What I´ve tried so far is to project the widened beam (after convex lens) on a distant wall and see how round it is. But I don`t know how exact this is.
Easy, if the beam is not traveling through the centre of the lens, it will be deflected. Mark where the spot is without the lens, once you insert the lens in the beam path, it is a matter of lining up the lens so the spot is centred on where it originally was without the lens.
This is all assuming that your lens surface is perpendicular to the beam path. If there is a slight tilt, it shouldn't matter if you have a good lens. If the beam noticably distorts (usually due to the presence of coma), simply realign it to minimise the abberations in your spot (i.e. trying to get it as circular as possible). This is pretty much what you described in your previous post.
It probably goes without saying that a good lens mount will help enormously.
Claude.
  • · Replies 19 ·
  • · Replies 20 ·
  • · Replies 102 ·
11K
  • · Replies 28 ·
10K
