The discussion revolves around determining the basis of the subspace spanned by three vectors, specifically whether to consider the basis of the row space or the column space of a matrix formed by these vectors. Participants explore the implications of row reducing the matrix and the correctness of their approaches in a testing context.
- Debate/contested
- Homework-related
- Mathematical reasoning
- One participant asks whether the basis of the subspace spanned by three vectors is found from the row space or the column space after forming a matrix.
- Another participant suggests that if one starts with rows and row reduces, the basis corresponds to the row space.
- A participant recalls a test experience where they wrote the vectors as columns and found the basis for the column space, which was marked wrong, leading to confusion about the correct approach.
- Some participants argue that if column operations are performed correctly, the answers should be equivalent, but the grading may reflect a misunderstanding of the initial setup.
- There is a discussion about the process of finding the basis for the column space, emphasizing the importance of identifying leading 1's after row operations.
- A participant describes their method of arranging vectors as columns, performing row operations, and returning to the original columns, questioning if this approach was valid.
- Another participant provides a simple example to illustrate the concept of spanning and suggests that the operations should not lead to confusion if done correctly.
- A participant shares a specific test question and their solution, asserting confidence in their algebra and the correctness of their answer.
- One participant expresses skepticism about the grading and suggests consulting the TA or professor for clarification.
Participants express differing views on the correctness of their methods for finding the basis of the subspace, with some uncertainty about grading practices and the interpretation of operations performed on the matrix. No consensus is reached regarding the best approach or the implications of the grading outcomes.
Participants highlight potential confusion arising from the distinction between row and column operations, as well as the importance of clearly stating the method used in tests. There are references to specific grading experiences that may not reflect a universal standard.
