Solving Vectors: Boater Needs to Cross River at 20mph
The discussion centers on solving a vector problem involving a boater crossing a river with a current. The river is 0.75 miles wide, and the boat can travel at 20 mph while the current flows at 5 mph. To determine the correct heading, participants suggest using a right triangle to represent the boat's velocity and the river's current. The angle needed to offset the current can be calculated using the formula arcsin(5/20), leading to a definitive solution for the boater's heading.
  • Understanding of vector representation in physics
  • Knowledge of trigonometric functions, specifically arcsin
  • Familiarity with basic principles of motion and velocity
  • Ability to visualize and draw right triangles
  • Study vector addition and resolution of forces in physics
  • Learn how to apply trigonometric functions to real-world problems
  • Explore examples of motion in currents and their effects on navigation
  • Investigate the concept of resultant velocity in two-dimensional motion
Students studying physics, educators teaching vector concepts, and anyone interested in navigation and motion analysis in fluid dynamics.
tucky
Hi everyone…it feels like it has been a while but I have another question? This is dealing with vectors.
Q: A boater wants to cross a river that has a current of 5mph and measures .75 miles in width. If the boat can travel at 20mph through the water, what heading must it take in order to travel from A and arrive directly across the river at B?
A: I was thinking about making about making two right angle triangles back to back (each containing the same measurements) The bottom of the triangle being (.75/2=.375).
I used the 5mph as deceleration? However, I am not sure if one can do that.
So this is how I tried to solve it…but I think it is wrong!
v v0+at
v20mph + -5mph (t)
t4s
y=y0 +v0(t)+.5a(t^2)
y=0+8.94m/s(4s) +.5(2.2m/s^2)(16)
y=18.6…but that seems too big so I need help!
Thanks,
Tucky
Try vector representation. (The given width, you should recognize, is extraneous information toward finding the heading for linear flow.)
Think of a right triangle with legs of 20 mph and 5 mph, perpendicular and parallel to the river's flow. Find the resultant direction needed to offset the river's velocity.
"I used the 5mph as deceleration? However, I am not sure if one can do that."
Did you really think about this? In the first place the problem says nothing about "acceleration" or "deceleration". In the second, 5 mph is a speed, not an acceleration.
I don't see any reason to draw TWO right triangles. Draw a line directly across the river from A to B- that represents the actual course of the boat. Draw a second line perpendicular to that- straight up the river and mark its length as 5 (mph): that represents the river current.
Now draw the hypotenuse of that triangle and mark its length as 20 (mph): that represents the speed of the boat (Loren Booda had a slight error when he said "legs of 20 mph and 5 mph"). Since you are only asked for the angle, you can use arcsin(5/20).
  • · Replies 22 ·
