Im having trouble with a few preoblems.
  • Thread starter Thread starter thschica
The original poster is facing difficulties with several physics problems related to projectile motion and free fall. The problems involve calculating time of flight, height, and speed in various scenarios, including a kangaroo's jump, a helicopter dropping a package, and a stone thrown from a cliff.
  • The original poster attempts to apply kinematic equations but encounters negative values, prompting questions about the correct equations and initial conditions. Some participants ask for clarification on the equations used and suggest re-evaluating the setup of the problems.
Participants are engaged in clarifying the original poster's approach and discussing the application of kinematic equations. There is an emphasis on showing work and understanding the underlying concepts rather than providing direct answers.
The original poster expresses uncertainty about the equations to use and mentions receiving negative results, indicating potential misunderstandings in the application of physics principles. There are reminders about forum rules regarding showing work before seeking help.
thschica
Im having trouble with a few problems.
1.A kangaroo jumps to a vertical height of 2.5 m. How long was it in the air before returning to Earth?
? s ( On this problem I keep getting a negative number.I know that this on is wrong for sure. What equation should I be using?)
3. A helicopter is ascending vertically with a speed of 6.00 m/s. At a height of 170 m above the Earth, a package is dropped from a window. How much time does it take for the package to reach the ground?
?s ( I have tried three equations but I still can figure out exactly which one I should be using)
10. A stone is thrown vertically upward with a speed of 13.0 m/s from the edge of a cliff 72.0 m high
(a) How much later does it reach the bottom of the cliff?
? s
(b) What is its speed just before hitting?
?m/s
(c) What total distance did it travel?
?m
(Once again I am getting negatives!)
25. A rock is dropped from a sea cliff and the sound of it striking the ocean is heard 6.6 s later. If the speed of sound is 340 m/s, how high is the cliff?
? m (This one I am not sure what I am doing wrong)
Did you check the "rules" for this Forum (see "Read this before posting"). We aren't going to do your homework for you. Show us what you have tried or at least what ideas you might have about the problem.
This link should give you all the info you need to start solving the problems.
You have to show your work before asking for help, that's the rule here. :)
I know how to do #10 but #1 is the one I am having the most trouble on.Can someone help me?
Show what you did to get a negative number.
I said 2.5m(t)+.5(-4.80)t^2
Why did you use -4.80?
Were you trying to use this formula?
[itex]x = x_0 + v_0 t + .5 a t^2[/itex]
yes I was.I meant 9.8
OK, so how were you planning to use that formula? If you start at ground level, you'll need to figure out the initial speed. But if you realize that the kangaroo's motion going up is a mirror image of its motion going down, you can apply the formula starting at the top of the motion where the speed is zero. Give it another shot. (Define all your values before "plugging in".)
9K
