How Do You Find a Plane Orthogonal to a Given Line?
  • Thread starter Thread starter Whatupdoc
    Orthogonal Plane
The discussion revolves around finding an equation of a plane that passes through a specific point and is orthogonal to a given line represented in parametric form. The problem involves understanding the relationship between vectors and planes in three-dimensional space.
  • The original poster attempts to identify vectors related to the problem but expresses confusion about the overall approach. Some participants suggest finding a vector parallel to the line and using the dot product to establish the plane's equation. Others question the notation used by a participant and emphasize understanding the parametric representation of the line.
The discussion is ongoing, with participants exploring different methods to approach the problem. Some guidance has been offered regarding the use of vectors and the dot product, but there is no explicit consensus on a solution yet.
Participants note the complexity of the problem and the potential challenges for those new to this type of question. There is an acknowledgment of the need for foundational understanding before tackling the current problem.
Whatupdoc
Find an equation of a plane through the point (-1, -2, -3) which is orthogonal to the line x=5+2t,y=-3-5t,z=2-2t
in which the coefficient of x is 2.
______________________________=0
i don't get this problem at all, but here's what i came up with after sitting here at the computer for a long time attempting to do this problem.
okay i know that by theorem, The vector a X b is orthogonal to both a and b.
a = <-1,-2,-3>
b= <2,-5,2>
that's all i came up, i attempted many different ways, but it doesn't make sense at all, can someone lend me a hand?
Ok, here's a plan: Find out the general form of a vector parallel to the line. (it will be a function of two parameters; say you labeled them t_1 and t_2.)Write out the form of a vector that lies in the plane (it will be a function of x,y & z). Then take the dot product of those two vectors and set it equal to 0. This is the equation of your plane. Now chose a particular vector parrarel to the line such that the coeff. of x is 2... that is to say, set t_1 and t_2 such that the coeff. of x is 2.
I understand that this might sound very confusing but try your best to progress. If you get stuck, or if after thinking very hard about it, you still can't find a way, I'll help you some more. Good luck!
N*r = n*r_0 is the equation I am looking for right?
i am totally lost here, book doesn't help much either, can you help me start it.
What are N,r,n and r_0 ?!
Have you done more simple similar problems before? If you're new to this kind of problem then this one is a rought introduction IMO!
Let's start with the first step of my plan. Let's find the general form of a vector parallel to the line. The equation of the line is written in parametric form. It means that for any value of t, the point (x,y,z)=(5+2t,-3-5t,-2-2t) is on the line. Ok, so let's find two points on the line by setting t = t_1 and t = t_2. Our two points are [itex]\vec{P}_1 = (5+2t_1,-3-5t_1,-2-2t_1)[/itex] and [itex]\vec{P}_2 = (5+2t_2,-3-5t_2,-2-2t_2)[/itex]. By means of a simple drawing, you can convince yourself that [itex]\vec{P}_1 - \vec{P}_2 = (2(t_1-t_2), -5(t_1-t_2), -2(t_1-t_2))[/itex] is a vector parallel to the line (it is in fact IN/MERGED WITH the line).
Now, make sure you understand every step in this paragraph and do step 2 on your own. Supposing (x,y,z) is a point in the plan, use the same method as above (substraction) to find a vector that is parallel to the plan.
  • · Replies 22 ·
  • · Replies 21 ·
