Investigating Redox Reactions Involving Potassium Permanganate
  • Thread starter Thread starter dajugganaut
    Reactions Redox
The discussion centers on the redox reactions involving potassium permanganate (KMnO4) and potassium halides (KCl, KBr, KI) in an acidic environment, specifically with sulfuric acid (H2SO4). It is established that KBr and KI react with KMnO4 due to their oxidation numbers being suitable for oxidation, while KCl does not react because the oxidation number of chlorine (-1) is too low for oxidation by KMnO4. The oxidation numbers for bromide and iodide ions are +1 and +7, respectively, allowing for their oxidation in this reaction.
  • Understanding of redox reactions and oxidation states
  • Familiarity with potassium permanganate and its properties
  • Knowledge of potassium halides and their chemical behavior
  • Basic chemistry concepts regarding acidic environments and their effects on reactions
  • Research the specific oxidation states of halide ions in redox reactions
  • Study the role of sulfuric acid in facilitating redox reactions
  • Explore the applications of potassium permanganate in various chemical reactions
  • Investigate other halides and their reactivity with potassium permanganate
Chemistry students, educators, and researchers interested in redox chemistry and the behavior of halides in oxidation-reduction reactions.
dajugganaut
Hi all,
The other day in chemistry class, we carried out several different redox reactions. In one set of the experiments, we reacted potassium permanganate with 3 different potassium halides (KCl, KBr, KI). this particular redox reaction also requires an acidic environment, so sulfuric acid was added.
Some of my friends believe that they saw KBr and KI react with potassium permanganate, but not KCl. I'm looking over the equations for each of the reaction and I can't figure out why KBr and KI would react but not KCl (furthermore, I can't even be sure that KBr and KI reacted at all.)
Does anyone have any ideas?
[ The ON for Mn is 7+ in potassium permanganate. This is the maximum ON for Mn. So naturally, I thought that all reactions would proceed, as bromide, chloride and iodide ions are not at their maximum ON ]
The reason why KCl did not react with potassium permanganate is because the chloride ion does not have a high enough oxidation number to be oxidized by potassium permanganate. The oxidation number of chlorine in KCl is -1, which is too low for it to be oxidized. Bromide and iodide ions, however, have oxidation numbers of +1 and +7 respectively, which are high enough for them to be oxidized. That is why the reaction proceeded with bromide and iodide ions, but not with chloride ions.
22K
9K
15K
