Relationship between molarity & concentration?
The discussion centers around the relationship between molarity and concentration, particularly in the context of determining the molarity of sugar in unknown solutions based on experimental data. Participants explore the definitions and distinctions between different types of concentration measurements and their implications for calculating molarity.
  • One participant describes an experiment to estimate the concentration of sugar in solutions and expresses confusion about how to calculate molarity from their findings.
  • Another participant clarifies that molarity is a specific type of concentration, suggesting that the original participant likely measured weight percentage concentration.
  • A participant provides details about their calibration curve, indicating it was created using known molar concentrations of fructose, but expresses uncertainty about the type of concentration measured.
  • Another reply asserts that if the calibration curve was based on known molar concentrations, then the values obtained from the curve represent molar concentration.
Participants do not reach a consensus on the specific type of concentration measured in the experiment. There are multiple viewpoints regarding the definitions and relationships between molarity and other forms of concentration.
Participants note the lack of clarity regarding the type of concentration measured and the implications for calculating molarity, highlighting potential gaps in understanding the definitions and applications of concentration in their experimental context.
confusedbyphysics
Hello! In my chemistry lab we did an experiment where the purpose was to find the estimated concentration of sugar in unknown solutions. We used 10 mL of each solution, and I determined the mass of the solution of each unknown. From there I calculated the density (mass over volume). Using that I figured out an estimated concentration using a calibration curve. Now I need to find out the estimated molarity. I am confused about the relationship between concentration and molarity. How do I figure out the molarity of the unknown substances? I know 1 mol of sugar = 180.16 g, but I do not know where to go from there. Are molarity and concentration the same thing?
Could someone clue me in on how to determine the molarity? I would be so grateful, thank you!
Chemistry news on Phys.org
Molarity is a kind of concentration. You don't state what kind of concentration you have measured - probably weight percentage.
Check out these concentration lectures.
Hello Borek and thank you for the reply!
The calibration curve I used to estimate the concentration of the unknown solutions was made through making five standard solutions (1.0 M, .75 M, .50 M, .25 M, .10 M) of fructose in distilled water. I made the solutions by making a 100 mL stock solution, and then used that to make the varies solutions in a 10 mL tube. Then I found out density and made my calibration curve, where concentration is the x-axis and density is the y axis. I am not sure what kind of concentration this would be! (my teacher has not even told me there are various forms of concentration!)
If calibration curve was prepared with solutions of known molar concentrations, what you have read from your curve is molar concentration.
  • · Replies 131 ·
11K
  • · Replies 0 ·
