Fixing the Mess of Logging into Account2 on Linux Fedora2
  • Thread starter Thread starter djeipa
    Linux
The discussion revolves around troubleshooting login issues with account2 on Linux Fedora2, specifically addressing a message related to the local domain that appears before the KDE desktop environment loads. Participants also explore a separate networking issue regarding pinging between two computers.
  • Experimental/applied
  • One participant describes a login issue with account2, mentioning a message about a problem with localdomain.domain and a file in /etc/.
  • Another participant requests the exact message to better understand the issue and inquires about how the new user was created.
  • A participant speculates whether the message pertains to a hosts file.
  • One participant suggests editing the hosts file to include a specific line to resolve the issue, proposing to add the line "127.0.0.1 localhost.localdomain" if it is not already present.
  • Another participant raises a new issue about networking, asking why computer A can ping computer B but not vice versa, despite firewalls not being a problem.
  • A participant provides potential reasons for the ping issue, suggesting that computer B might be configured to not respond to pings and recommends using terminal commands for mounting shared drives instead of graphical tools.
Participants express differing views on the best approach to resolve the login issue and the networking problem, with no consensus reached on the solutions proposed.
Participants mention specific commands and configurations, but there are unresolved assumptions regarding the exact nature of the login message and the network settings on the computers involved.
djeipa
I set up 2 accoutns in Linux Fedora2 , with account1 I can log in just fine but with account2, I can also log in but before KDE's main screen appears, a message shows up *i have problem with localdomain.domain ...file in /etc/* (I can't remember the whole messagfe but something like that).
do you know how to fix this problem ? its fine but kind of mess, at least I think so.
Computer science news on Phys.org
You're going to have to get the exact message.
Did you create the new user on the command line or using the kde tool?
does it talk about a hosts file?
Yes, computergeek guesses conrrectly, how can i stop it from appearing everytime I log in ?
open up a terminal and go to /etc and open the hosts file up using your favorite terminal editor. then add the line
if that is already there, open up another terminal and type ifconfig and then write down your computer's IP address.
then on the next open line in the hosts file, put:
<ipaddress> localhost.localdomain
Thank you, thank you...so so much, I have another problem
Do you know why computer A can ping computer B but computer B can't ping computer A ? Firewalls on or off in this local cable sharing are not a problem. Just now that I can't do things like setting up [\\computerAName\ASharedFolder] from computer B's sharing widzard anymore. How can i fix this problem ? Thanks
There can be a lot of reasons. For instance, you can set computer B up to not respond to pings, so it simply just devours the packets , but yes I think you're sort of thinking the right thing. To mount a shared drive on linux I always use mount from the terminal, if you do ~# smbmount then it will come up with the info needed to use mount and to specify samba and all that , I tend to do everything from the terminal that I can before turning to wizards / tools , just because it tends to have more stable results.
you can also do
# man mount
I think its like mount -t smbfs -o username=uname,pass=password //computerinlowercase/shareincasesensitive /directory/tomountit
if you don't do the whole -o thing then it will just say Password? .. if there isn't a pass just hit enter
  • · Replies 24 ·
  • · Replies 24 ·
11K
  • · Replies 123 ·
21K
  • · Replies 30 ·
