Rate of Change in a coordinate plane
The discussion revolves around a calculus problem involving the rate of change of distance between two points moving along the x-axis and y-axis at constant rates. The original poster describes their confusion regarding how to apply the distance formula and differentiate it to find the rate of change of distance.
  • Participants discuss the need to develop an equation for the distance between the two points and differentiate it. There are attempts to clarify the correct coordinates and the application of the distance formula.
Some participants have provided guidance on using the distance formula and differentiating it, while others express uncertainty about the correct approach and the application of time as a variable in the context of the problem. Multiple interpretations of the distance calculation are being explored.
There is a mention of the original poster's struggle with the differentiation process and the need to reflect the changing coordinates as functions of time. The problem's setup and the rates of change for x and y are also under discussion.
NYmike
Hi. I am drawing a complete blank on this calc problem.
Point a moves along the x-axis at the constant rate of 'a' ft/sec
while point b moves along the y-axis at the constant rate of 'b'
ft/sec. Find how fast the distance between them is changing when A is
at the point (x,0)and B is at the point (0, y).
I know that dx / dt = a, and dy / dt = b, however I am stuck on where to go afterwards. I drew a graph and thought that the slope would lead
me to an answer, but I can't quite figure it out. Since I am looking for the change in distance between the two points I figured that I may have to incorporate the distance formula rather than some formula with slope, however I can't quite figure out how to go about it. :redface:
Thanks in advance for any help.
The wording of the problem provides the clue as to how to proceed.
This tells you two things:
1. You need to develop an equation for the distance between the points
2. differentiate (1) and evaluate at the desired x & y
[tex]d = \sqrt{\Delta x^2 + \Delta y^2}[/tex]
[tex]\frac{dx}{dt} = a[/tex]
[tex]\frac{dy}{dt} = b[/tex]
That's what I've come up with so far.
Now, since I am trying to find the rate of change of the distance, then I believe I am looking for [tex]\frac{dd}{dt}[/tex]
Taking the derative of the distance formula directly would be pretty sloppy, so I think I should plug in for the values of x and y and then evaluate the deriv. I believe that the two points in question are: (x+a, 0) and (0, y+b). Is this correct? This is where the points A and B are after 1 second.
If so, then [tex]\Delta x = (x+a) - (0) = (x+a)[/tex] and [tex]\Delta y = (0) - (y+b) = -y-b[/tex]
:eek: Even after plugging in the deriv is ridiculous.
There must be a way to plug in something else. Am I using the wrong coordinates/formula?
I don't see a "t" anywhere in there. Maybe I am wrong, but it seems that somehow your distance equation needs to reflect that X and Y are changing as a function of t.
Try replacing [itex]d = \sqrt{\Delta x^2 + \Delta y^2}[/itex] with [itex]d = \sqrt{x^2 + y^2}[/itex]. Maybe you've been studying partial derivatives recently.
Carl
I was taught that [tex]\frac{d(some var)}{dt}[/tex] = the Rate of Change of some var. with respect to time. The rate of change of x with respect to time is 'a', and of y with respect to time is 'b'. I am trying to find the rate of change of distance (var. d) with respect to time. I am pretty sure that this part is correct?
Carl
Sorry, but I am not sure where you are going with this.
When [tex]d = \sqrt{x^2 + y^2}[/tex] :
[tex]\frac{dd}{dt} = \frac{1}{2} (x^2 + y^2)^\frac{-1}{2} (2x\frac{dx}{dt} + 2y\frac{dy}{dt})[/tex]
[tex]\frac{dd}{dt} = \frac{1}{2} * \frac{1}{\sqrt{x^2+y^2}} * 2xa + 2yb[/tex]
[tex]\frac{dd}{dt} = \frac{xa + yb}{\sqrt{x^2+y^2}}[/tex]
I have 2 points, so which would i plug in for x and y??
x and y were given as data to the problem. You don't plug anything in for them. You're done and I think you got the right answer.
Carl
  • · Replies 23 ·
