Projectile Motion - need help
The discussion focuses on calculating the time required for a projectile, fired from the origin with an initial velocity \( v \) at an angle \( \alpha \), to cross a line defined by the equation \( y = ax \), where \( a \) is determined by the angle \( \beta \). The projectile's vertical position is described by the equation \( y = y_0 + v_0(\sin \alpha)t - 4.9t^2 \). To find the intersection of the projectile's path and the line, the user must express \( y \) in terms of \( \beta \), set it equal to the projectile's equation, and solve for \( t \) by determining the value of \( x \) at which both equations intersect.
  • Understanding of projectile motion equations
  • Knowledge of trigonometric functions and angles
  • Familiarity with algebraic manipulation of equations
  • Basic knowledge of coordinate geometry
  • Study the derivation of projectile motion equations in physics
  • Learn how to solve systems of equations graphically and algebraically
  • Explore the relationship between angles and slopes in coordinate geometry
  • Investigate the effects of initial velocity and angle on projectile trajectories
Students studying physics, educators teaching projectile motion concepts, and anyone interested in applying mathematical principles to real-world motion problems.
don_anon25
Projectile Motion -- need urgent help :)
If a projectile is fired from the origin of the coordinate system with an initial velocity v and in a direction making an angle alpha with the horizontal, calculate the time required for the projectile to cross a line passing thorugh the origin and making an angle beta less than alpha with the horizontal.
I know that the position of the projectile is described by
y=y0+v0(sin alpha)*t-4.9t^2.
I let the line be y=ax. I also drew a triangle with Beta as the angle, y=ax as the opposite side, and x as the adjacent side. I'm assuming I want to find y in terms of Beta and then set this equal to y in my projectile motion equation...then solve for t?
Thanks in advance!
Combine this with the equation for the horizontal position and you can get y as a function of x.
Write the equation of the straight line. (What is "a" in terms of beta?)
Now you can find the value of x where the two functions intersect. And then plug that into one of the other equations to solve for the time.
