Kepler's 3rd Law and the Doppler Effect
The discussion revolves around a problem involving a space probe in circular orbit around a distant planet, emitting a radio signal with a specific wavelength. Participants are tasked with calculating the mass of the planet based on observed variations in the signal's wavelength due to the Doppler effect, while utilizing Kepler's 3rd Law.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss various equations related to orbital mechanics and the Doppler effect, questioning the relevance of multiple wavelength values provided in the problem. Some express uncertainty about the definitions of variables and the applicability of certain equations.
The discussion is ongoing, with participants exploring different approaches and equations. Some have offered alternative equations for consideration, while others express confusion about the problem's requirements and the definitions of variables involved.
Participants note that their current knowledge is limited to Kepler's 3rd Law and the gravitational force equation, indicating constraints on the methods they can apply to the problem.
dekoi
Question:
Imagine a space probe has been placed in a circular orbit about a distant planet. The probe emits a continuous radio signal with a wavelength of 8 m. You measure the signal from earth, and find it to have a wavelength that varies regularly between 7.99943 m and 8.00057 m, with a period of 4.5 hours. Assuming that you are in the plane of the probe's orbit, and that you are not moving, calculate the mass of the planet.
This is what I have done...
By substituting into different equations, I end up with the equation:
a = λ / 2pi
Using Kepler's 3rd Law:
P^2 = a^3 / mt
I end up with :
mt= (λ / 2pi)^3(1 / P)^2
However, I do not know why I am given 3 different values for wavelength, should this be applied into the answer or not?
a = λ / 2pi
You got that the semimajor axis of the orbit was comparable to the wavelength of the radiation? I'd like to see which equations you used to get that result. The only radiation for which that would be true is the gravitational variety.
Try instead using:
[tex]\frac{\Delta \lambda}{\lambda}=\frac{v}{c}[/tex]
and
[tex]v_c=\sqrt{\frac{GM}{a}}[/tex]
I just did what my teaching assistant told me to do. I don't think it's correct either.
I'm assuming that "c" is the speed of light.
What is the M? Mass of the planet?
And what can I do with that equation for v?
Sorry, I forgot to define my variables: M is the planet's mass, v is the velocity relative to your line of sight, vc is the circular velocity of the orbit, [itex]\Delta \lambda[/itex] is the shift in wavelength relative to its rest frame value, [itex]\lambda[/itex] is the rest frame value of the wavelength, c is the speed of light, a is the semimajor axis, and G is the gravitational constant.
We haven't learned that much information in order to use those equations. The most we have learned is Kepler's 3rd Law and the Gravitational force equation.
F=GMm/ R^2
F=GMm/ R^2
The second equation follows simply from Kepler's Third Law, but you do have to know the first one in order to do the problem. I suggest a google (or PF) search on the doppler effect.
Okay, thank you anyway.
