| Thread Closed |
Vacuum to Vacuum Amplitudes and Functional Integrals |
Share Thread | Thread Tools |
| Oct13-05, 07:59 PM | #1 |
Hi,
I am reading chapter 5 of Ryder regarding path integrals and vacuum to vacuum transition amplitudes in presence of source. I follow the math but don't have a clear physical picture. The formula is: [tex] Z[J]=\int Dq \: exp ( \frac{i}{h}\int dt(L+hJq+\frac{1}{2}i\epsilon q^2) ) [/tex] Can someone explain what this is the transition amplitude of please? I think its saying: 1) pick a point in space 2) overlay a source (eg EM field) 3) A particle may be raised above the vacuum ground state at some point but ultimately at the beginning and end of time the vacuum will stay the vacuum - ie the vacuum will never turn into a stable particle. I don't really think this is correct so please correct me! :) |
| Oct14-05, 04:12 AM | #2 |
IMHO, this formula is of the generating functional, which is not the transition amplitude. However, the n-th functional derivative with respect to J of the generating functional gives you the n-point Green function. The n-point Green function is related to the transition amplitude of a scattering event involving n particles, i.e. it is related to one element of the S-matrix <in|out>, which can be written as a function of creation and annihilation operators acting on <0| and |0> (which in turn can be expressed as a time ordered product of fields).
| Oct14-05, 04:17 AM | #3 |
Two words for ya: Read Zee !!
Daniel. |
| Oct14-05, 08:45 AM | #4 |
Recognitions:
Vacuum to Vacuum Amplitudes and Functional IntegralsThis is basically the start formula of chapter 6 which denotes the path-integral for scalar fields. L is Lagrangian which is proportional to the amount of phase-changes over the trajectory of the particle as a result of it's rest mass and motion. The J term takes account of the phase changes over the trajectory of the particle as a result of the Electric and Magnetic Aharonov Bohm effects. (The EM interactions) Regards, Hans |
| Oct14-05, 11:24 PM | #5 |
What do you mean phase change over trajectory - the phase change of what. I can conceptually picture phase changes for things like EM waves for example but I have a block when we talk about the phase of a particle. |
| Oct14-05, 11:27 PM | #6 |
Thanks. The QFT books I currently learn from are: Ryder Mandl and Shaw Peskin and Schr. Weinberg - Quantum theory of fields. Do you feel that Zee is sufficiently superior to these that it is worth purchasing in addition? If so I will certainly purchase it. |
| Oct15-05, 06:29 AM | #7 |
Recognitions:
terms of the "sum over phase changes". A very popular introduction on the elementaries of this is Feynman's "QED The strange theory of matter and light" Be aware that not all math is what it seems in these texts, e.g: in [itex]\langle x_b | e^{-iHt/\hbar} | x_a \rangle [/itex] the Hamiltonian H is an operator (it includes differentiation) which makes the whole exponent an operator. Regards, Hans. |
| Oct16-05, 01:16 PM | #8 |
Ok, thanks Hans. I'll check Peskin.
| Oct17-05, 06:24 AM | #9 |
Daniel. |
| Oct17-05, 04:55 PM | #10 |
thx dextercioby. A friend has Zee so I'll just borrow.
Incidently. Its pretty obvious that you have a really good grasp of anything quantum. (qft qm, all the maths) and probably a bunch of other stuff. What would be on your 'MUST READ AT GRAD SCHOOL' list for any budding theoretician?? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Vacuum to Vacuum Amplitudes and Functional Integrals
| Evaluating Functional integrals | Beyond the Standard Model | 3 | ||
| Question about vacuum and vacuum meter | General Physics | 1 | ||
| Inflationary vacuum and the true vacuum | Cosmology | 17 | ||
| Do vacuum fluctuations contribute to vacuum polarization | High Energy, Nuclear, Particle Physics | 2 | ||
| Does a Vacuum Cleaner work inside a Vacuum? | General Physics | 12 | ||
