Limit of x ln(a) - ln(a^x+b) for a>1, b!=0
  • Context: Graduate
  • Thread starter Thread starter bomba923
    Limit
The discussion revolves around evaluating the limit of the expression \( x \ln(a) - \ln(a^x + b) \) as \( x \) approaches infinity, where \( a > 1 \) and \( b \neq 0 \). Participants explore various approaches to simplify and analyze the limit, including algebraic manipulation and the potential application of L'Hôpital's rule.
  • Homework-related
  • One participant poses the limit question, expressing curiosity rather than it being a homework problem.
  • Another suggests using logarithm rules to rearrange the expression, aiming to simplify the limit to a single logarithm.
  • A different participant proposes a specific rearrangement of the limit into the form \( \lim_{x \to \infty} \ln \left( \frac{a^x}{a^x + b} \right) \) and notes the presence of an indeterminate form.
  • Further, a participant advises dividing both the numerator and denominator within the logarithm by \( a^x \), leading to a new limit expression that simplifies the analysis.
  • One participant introduces L'Hôpital's rule, explaining its applicability to forms that yield \( \frac{0}{0} \) or \( \frac{\infty}{\infty} \), but does not assert its use in this specific case.
Participants do not reach a consensus on the best method to evaluate the limit, and multiple approaches are proposed without resolution of which is most effective.
There is mention of an indeterminate form within the logarithm, and the discussion includes various algebraic manipulations that may or may not lead to a conclusive evaluation of the limit.
bomba923
*Not really homework, just curious:
[tex]\forall a > 1 , b \ne 0, \lim_{x\to \infty} [ x \ln (a) - \ln (a^x + b) ] = \; {?}[/tex]
Use common logarithm rules to rearrange the expression inside the limit. You should end up with only the limit of a single logarithm.
I think you mean rearranging the expression as:
[tex]\mathop {\lim }\limits_{x \to \infty } \ln \left( {\frac{{a^x }}{{a^x + b}}} \right)[/tex]
Hmm, how would I advance from there? An indeterminate form exists within the natural logarithm, although I'm not quite sure that would justify using L'Hopital.
Perhaps some additional algebraic manipulation is required?
You can then divide both numerator and denominator within the natural logarithm by ax, something like:
[tex]\lim_{x \rightarrow \infty} \ln \left( \frac{a ^ x}{a ^ x + b} \right) = \lim_{x \rightarrow \infty} \ln \left( \frac{\frac{a ^ x}{a ^ x}}{\frac{a ^ x + b}{a ^ x}} \right) = \lim_{x \rightarrow \infty} \ln \left( \frac{1}{1 + \frac{b}{a ^ x}} \right)[/tex].
Can you go from here?
L'Hopital's rule can be use to solve [itex]\frac{0}{0}[/itex], or [itex]\frac{\infty}{\infty}[/itex] form. It states:
[tex]\lim_{x \rightarrow \alpha} \frac{f(x)}{g(x)} = \lim_{x \rightarrow \alpha} \frac{f'(x)}{g'(x)}[/tex].
Note that it can only be used when f(x), and g(x) both tend to 0 or infinity.
Viet Dao,
