Heating Water: Does Energy Loss Affect Temperature Change?
  • Thread starter Thread starter charlesworth
    Heating
The discussion centers on the non-linear relationship between time and temperature when heating water at a constant power. The equation Q = mc(ΔT) is highlighted as insufficient for modeling this scenario, as it does not account for the water's current temperature or energy loss to the environment. As the water's temperature rises, the rate of heat loss increases due to a greater temperature gradient between the water and surrounding air, leading to a deceleration in temperature increase despite a constant energy input.
  • Understanding of thermodynamics principles, specifically heat transfer.
  • Familiarity with the equation Q = mc(ΔT) and its limitations.
  • Knowledge of temperature gradients and their effect on heat loss.
  • Basic concepts of energy conservation in closed systems.
  • Research the effects of heat loss in open systems, particularly in fluids.
  • Explore advanced thermodynamic models that incorporate variable heat transfer rates.
  • Study the impact of environmental factors on heating processes, such as air flow and insulation.
  • Learn about the principles of convection and conduction in heat transfer.
Students and professionals in physics, engineering, and environmental science, particularly those interested in thermodynamics and heat transfer dynamics.
charlesworth
Suppose a constant volume of water is being heated up by a constant amount of power. After some time it is noted that the rate of change of temperature is slowing down. (In this scenario, assume all temperatures to be between 10 and 90 degrees celsius)
What would cause this non-linear relationship between time and temperature?
Q = mc(delta)T --> This does not take into account the masses current temperature.
Does it have to do with energy loss of the substance to outer environment?
1) I don't know what you mean with "masses current temperature" :confused:
2) Your equation is only valid for a constant flux of heat in time.
3) You are not taking into account possible heat losts to the environment.
4) In a mathematical model, using ONLY the equation you posted it is impossible a non linear relation between T and Q.
Yes. The rate of heat loss depends on the temperature gradient. The more you heat the water, the greater the temperature difference between the water and the surrounding air, and thus, the higher the rate of heat loss. Since you are supplying a constant rate of energy to the water, and the water is losing a larger rate of heat as its temperature increases, you will end up with a temperature increase of the water slowing down.
Zz.
  • · Replies 19 ·
