Angular Velocity and Tangential Acceleration Explanation
The discussion revolves around angular velocity and tangential acceleration in the context of a rotating disk. The original poster presents two questions regarding the relationship between points on the disk and their respective angular velocities and tangential accelerations.
  • Exploratory, Assumption checking
  • The original poster attempts to reason that the angular velocity of point Q is the same as that of point P due to their positions along the radius of the disk. They also argue that the tangential acceleration is zero because the disk rotates at a constant rate.
Some participants have pointed out the need for the original poster to show their work in order to receive assistance. The discussion appears to be ongoing, with a request for further engagement from others.
There is a mention of forum guidelines requiring participants to demonstrate their reasoning or work before receiving help, which may impact the flow of the discussion.
allstar1
angular velocity help!
Hi, I need help with the following 2 questions. My answers have *********
next to them. Any help is appreciated. Thank you.
1. A disk is rotating at a constant rate about a vertical axis through its center. Point Q is twice as far from the center of the disk as point P is. The angular velocity of Q at a given time is
Choices:
a) twice as big as P's
b) the same as P's *******************
c) half as big as P's
d) none of the above
i believe it's the same as P's, since and poing on radius r, has the same velocity on any point on the radius line.
2. When a disk rotates counterclockwise at a constant rate about a vertical axis through its center, the tangential acceleration of a point on the rim is
Choices:
a) positive.
b) zero. *******************
c) negative.
d) impossible to determine without more information.
i believe it's zero, since it's rotating at a constant rate, which means the acceleration is zero.
According to the PF Global Guidelines (to which you agreed), you have to show your work before you can receive help.
work is show to my answers.
anyone?
  • · Replies 30 ·
  • · Replies 17 ·
  • · Replies 71 ·
