Troubleshooting Ln: Tips to Improve Sleep
The discussion revolves around understanding the relationship between the complex variable version of arcsinh and its integral representation. Participants are exploring differentiation techniques related to the function y = ln[x + (1 + x^2)^(1/2)] and its connection to arcsinh(x).
  • Participants are attempting to differentiate the function y = ln[x + (1 + x^2)^(1/2)] and relate it to the derivative of arcsinh(x). Some express confusion about the differentiation process and the algebra involved.
There are multiple lines of reasoning being explored, with some participants providing clarifications and hints. Guidance has been offered regarding the differentiation process, but a consensus on the approach has not been reached.
Participants are grappling with the complexity of the differentiation and the algebraic manipulation required to connect the two forms of the function. There is an acknowledgment of the potential for confusion in the steps involved.
Focus
I've had troubled sleep because of this...:cry:
I tryed a lot and got this...
Can you spot any mistakes or give me hints on how to approach this
Thanks
That is an equation that shows the "complex variable" version of arcsinh (x) as equal to the integral version of it (on real values). Like a definition. You obtain the first with the complex functions sinhz and some algebra, and the second one with a trigonometric substitution (or using mathematica, hehe)
I am so confused...I know that the second one can be obtained by using y=arsinh(x) but I can't get the log of the function to differentiate to that:rolleyes:
It helps a lot if you write it clearly! I think you mean that IF
[tex]y= ln\left[x+ (1+x^2)^{\frac{1}{2}}\right][/tex]
then
[tex](1+x^2)\left(\frac{dy}{dx}\right)^2= 1[/tex]
which is the same as saying that
[tex]\frac{dy}{dx}= \frac{1}{(1+x^2)^{\frac{1}{2}}}[/tex]
then
The problem is I can't derive [tex]\frac{dy}{dx}= \frac{1}{(1+x^2)^{\frac{1}{2}}}[/tex] from [tex]y= ln\left[x+ (1+x^2)^{\frac{1}{2}}\right][/tex]...
I can only derive it from y=arsinh(x)
It seems like it pops right out from the chain rule.
Yep.
[tex]y= ln\left[x+ (1+x^2)^{\frac{1}{2}}\right][/tex]so
[tex]y'= \frac{1}{x+(1+x^2)^{\frac{1}{2}}}\left(1+(\frac{1}{2})(1+ x^2)^{-\frac{1}{2}}(2x)\right)\)[/tex]
Now factor that
[tex](1+ x^2)^{-\frac{1}{2}}[/tex]
out of the numerator and every thing else cancels!
Hmmm...I tried that but I'll do it again, cheers for the help :smile:
