How Do Sound Waves Interfere and How Does Light Travel in a Medium?
This discussion focuses on the interference of sound waves produced by speakers and their interaction with a listener. The first scenario involves two speakers 2m apart emitting sound at 300Hz, where the phase difference calculated is 3.35 radians, and the frequency for minimal sound is determined through destructive interference principles. The second scenario examines speakers at 800Hz and 1.25m apart, where the wavelength is calculated as 0.43m, leading to the identification of points of destructive interference. The discussion also touches on wave superposition and the visibility of an air bubble in a medium based on the refractive index.
  • Understanding of wave interference and phase difference
  • Knowledge of sound wave properties, including frequency and wavelength
  • Familiarity with the concept of destructive interference
  • Basic principles of wave superposition
  • Study the principles of wave interference in detail, focusing on phase differences
  • Learn about calculating sound wave properties using the speed of sound formula
  • Explore the concept of destructive interference and its applications in acoustics
  • Investigate the effects of refractive index on light behavior in different media
Students and professionals in physics, acoustics engineers, and anyone interested in the principles of wave behavior and sound interference.
dekoi
1.) Two speakers are on a wall 2m apart. A listerner stands 3.00m from wall in front of one of the speakers. An oscillator runs both speakers at 300Hz.
a.) What is the phase difference between two waves when they reach observer?
b.) What is the frequency closest to 300Hz to which the oscillator may be adjusted such that the observer hears minimal sound?
I began by finding the path difference between the two waves. One is assumed to be on the ground, so its path is 3.0 m long. The other is ~3.5 (sqrt(13)). For part (a) path difference is 0.61m. [itex]\Delta r = \frac{\phi}{2\pi}{\lambda}[/itex] and [itex]\lambda = \frac{v}{f}[/itex], hence i solved for [itex]\phi[/itex], and it turned out to be 3.35 rad. Can anyone verify this, and most importantly explain why i even did this? Any explanation would be great.
Part B asks me for the frequency when there is minimal sound. Minimal sound occurs when there is destructive interference. So according to my notes i equated the angle to [itex](2n+1)\pi[/itex]. Is this correct? What should i solve for and why?
2.) Two speakers are driven in phase by a common oscillator at 800Hz and face each other at distance of 1.25m. Locate the points along a line joining the two speakers where relative minima of sound pressure amplitude would be expected.
Once again, I am solving for the points where there is destructive interference. I could solve for wavelength via [itex]\frac{v}{f}[/itex]. Reload this page in a moment.. Thus wavelength equals 2.33m. Then i used the equation [itex]d=\frac{(2n+1)\lambda}{2}[/itex]. Is this correct? What do i solve for? Where do i go from there?
3.) Two sinusoidal waves combine in medium are described by:
[itex]y = 3sin\pi(x + 0.6t)[/itex]
and
[itex]y = 3sin\pi(x - 0.6t)[/itex]
Determine max transverse poistion of an element in medium at 0.250 cm.
Any beginning suggestions would be great. I suppose i could find the sum of the two waves (the superposition), but I am not sure where to go from there.
4.) A cube (n = 1.59) has a small air bubble inside. When a 1.90cm coin is placed over the bubble on the outside of cube, the bubble cannon be seen by looking down into the cube at any angle. However, when a 1.75cm coin is placed directly over it, the bubble can be seen by looking down into the cube. What is the range of the possible depths of the air bubble beneath the surface?
I attempted to draw the diagram for this, but couldn't get a clear understanding of the situation. If anyone could draw me a sample diagram, i would be very grateful.
The answer is right. The difference in path length means that the two sound waves will not be identical at that point. The phase difference is the number of wave lenghths difference divided by [itex]2\pi[/itex].
When two waves interfere the amplitudes of the two sound waves simply add together. If there is a half wavelength or at odd multiples of [itex]\pi[/itex] phase difference, the amplitudes sum to zero (one at a peak the other at a trough) and you have a node.
What are you using for the speed of sound? It should be about 344 m/s assuming room temperature. I get .43 m for the wavelength. So nodes will occur where the differences between the two speakers are odd multiples of half wavelengths. Work out the expression for the difference in distances at a point x between the speakers and use your formula [itex]d=\frac{(2n+1)\lambda}{2}[/itex]
AM
  • · Replies 19 ·
