Using a Rotary Potentiometer and Float
The discussion focuses on using a rotary potentiometer combined with a float to measure liquid levels in a tank for a physics coursework project. The setup involves connecting a multimeter as an ammeter and another as a voltmeter in parallel with the rotary potentiometer to record potential difference readings corresponding to water levels. The user seeks validation of their experimental design and understanding of the potential divider concept, confirming that a rotary potentiometer functions as a variable resistor and can effectively measure changes in voltage as the water level fluctuates.
  • Understanding of rotary potentiometers and their function as variable resistors
  • Basic knowledge of electrical circuits, including DC circuits
  • Familiarity with multimeter usage for measuring voltage and current
  • Concept of potential dividers and their application in measuring voltage changes
  • Research the principles of potential dividers and their applications in circuit design
  • Learn about calibration techniques for measuring instruments in experimental setups
  • Explore the use of constant current and constant voltage sources in electrical circuits
  • Investigate alternative methods for liquid level measurement, such as ultrasonic sensors
Students conducting physics experiments, electronics enthusiasts, and anyone interested in practical applications of rotary potentiometers in liquid measurement systems.
† please_help_me †
First off i'd like to say hi guys (and gals) - this may be my first post, but should hopefully be the first of many:smile:
Basically i have a problem regarding some physics coursework. We're actually conducting these on the 8th of November - and i have a deadline of the 20th of November. I've decided to use a rotary potentiometer, with the aid of an attached float to measure the amount of liquid in a tank. I'll basically create your basic circuit, with an ammeter attached (multimeter to be precise) and then attach a voltmeter (multimeter..) in parralel with the rotary potentiometer. This is probably hard to visualise, but the pictures i have just spent the last 20 minutes making are to big to be uploaded :mad:
Basically, I am planning on callibrating my several potential difference readings, for the level of the water in the tank. the float will (quite obviously) float on the top of the surface of the water. So when the level is decreased, this should move the float, which should in effect turn the rotary potentiometer, which should in effect alter resistance, which should in effect alter the ptential diifferences i record. So i should be able to create a table of values (i.e. when the potential difference is X then the water level in the tank will be Y)
Know your probably wondering why I've spent all this time typing this, but I am (unbelieveably) anxious that there are some flaws in what i am doing. If you spot any, that's one reason to reply :redface: If there are any ways which i could improve this experiment, that's a second reason to reply :redface:
The main problem i have however is the theory behind it. I don't understand/know how to explain the way i have used a potential divider (is the rotary potentiometer a form of a potential divider?).
A rotary potentiometer is a variable resistor. The method you are attempting has been used quite a lot. It's a sound concept. It has some drawbacks, but they are not going to effect you in your case. If you used a simple DC circuit, you can use a power supply to provide a constant current source signal to the system. As the resistance changes so will the voltage across the resistor (i.e. the level in the tank). Or you could use a constant voltage source and measure the current changes. Either way, it should work out fine.
  • · Replies 17 ·
  • · Replies 16 ·
