What is the new orbit of the Earth after a collision with Halley's comet?
The discussion revolves around the hypothetical scenario of Earth's orbit changing after a collision with Halley's comet. The original poster presents a problem involving the new semi-major and semi-minor axes of Earth's orbit, assuming an increase in speed post-collision. The context is rooted in orbital mechanics and the conservation of angular momentum and energy.
  • Participants explore whether angular momentum is conserved during the collision and question the conservation of the radius (R) of the orbit. There are discussions about the implications of increased kinetic energy on potential energy and the resulting changes in the orbit.
The discussion is active with participants questioning assumptions about conservation laws in the context of the collision. Some have provided insights into the relationship between kinetic and potential energy, while others have raised further questions about the implications of the new speed on the orbit.
There is an underlying assumption that the Earth initially moves in a circular orbit before transitioning to an elliptical orbit after the collision. The problem is framed within the constraints of a hypothetical scenario, focusing on the effects of increased speed on orbital parameters.
Carolyn
The question is
If after Halley's comet hits the earth, the Earth continues to move in its initial direction but with a greater speed (1.12 times) , find the new semi-major and semi-minor ases of the new Earth orbit in terms of the original R.
So, my question is, do you think that the angular momentum of the Earth is conserved in this process? or is R conserved in the process( which means R does not change)?
The question assumes that the Earth is initially moving in the circular orbit, then after the collision it moves in a elliptical orbit.
Thanks for any help!
Why would you think R is conserved?
Why would you think that angular momentum of the Earth is conserved if there was an outside force (the collision of the Earth with a comet)?
If the Earth's speed, v, becomes 1.2v, then its square becomes 1.44v2 so the the Earth's kinetic energy is increased by a factor of 1.44. Of course, the potential energy, at that point, is still the same so the Earth's total energy has changed.
Carolyn said:
The question is
If the velocity increases by 1.12, then the Kinetic energy increases by the square of that. How much farther will the Earth have to travel out from the sun until its potential energy equals newly acquired kinetic energy? You'll have to do a diff eq of the forces involved given the new initial conditions of the added speed and initial tangential direction. Given the initial conditions of the location and direction of velocity, the acceleration is equal to the forces on the Earth divided by the mass of the earth.
  • · Replies 18 ·
10K
